Old 10-03-2013, 08:37 PM   #1
ns209
ns209's Avatar
Wilwood brake ?
Looking to install Wilwood rear brakes and d52 front calipers. Now what I want to know is if it will work with my factory style booster and master. My truck is a 70 c10 with front disk and rear drum
ns209 is offline   Reply With Quote
Old 10-03-2013, 10:16 PM   #2
Half-Fast
Re: Wilwood brake ?
You will need a new propoptioning valve.
Half-Fast is offline   Reply With Quote
Old 10-04-2013, 03:45 AM   #3
andrewmp6
Re: Wilwood brake ?
Depends the size calipers in the rear.
andrewmp6 is offline   Reply With Quote
Old 10-04-2013, 03:48 AM   #4
ns209
ns209's Avatar
Re: Wilwood brake ?
This rear kit
http://m.summitracing.com/parts/wil-140-10094-d
Old 10-04-2013, 11:07 AM   #5
jimmydean
jimmydean's Avatar
Re: Wilwood brake ?
The booster and master should work as long as you have a disc/disc proportioning valve, or an adjustable one.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-04-2013, 10:42 PM   #6
Pro Performance
Pro Performance's Avatar
Re: Wilwood brake ?
Agree, it is best to mainly match up the booster with the front system, and in your case, disc. So, as long as you have a disc master, you will be good. In most cases, the prop valve will be needed, and just a good idea to help dial in the rear.
We have our Pro1 Wilwood kit that uses the D52's front, Powerslot rotors, Rear D154 kit & SS lines front and rear. We use the D154, since it is a floating caliper and works a little better with the c-clip rear, and the caliper matches the front a little better (both being a gloss black smooth finish, e-brake cables, etc.)
If you wanted to use the same rotors you have, and switch to a plain rotor rear to match, it would be $360 cheaper.
http://www.azproperformance.com/Pro1...Brake-Kit.html
Pro Performance is offline   Reply With Quote
Old 10-05-2013, 03:53 AM   #7
ns209
ns209's Avatar
Re: Wilwood brake ?
Thanks guys sounds like I need a new propoptioning valve. Do you guys think I will notice a difference in braking?
Old 10-09-2013, 11:40 PM   #8
CHRIS67GMC
CHRIS67GMC's Avatar
Re: Wilwood brake ?
Ok you can run your master and it will work kinda.... If I am reading this correct you will have 4 wheel disc brakes so you need a 4 wheel disc brake master. Corvette ones work fine. Then you will need a adjustable prop valve to set brake bias. It is best to run 3/16 hard line to #3 hoses at the corners.
CHRIS67GMC is offline   Reply With Quote
Old 10-10-2013, 12:08 AM   #9
ns209
ns209's Avatar
Re: Wilwood brake ?
What year corvette will work?
Old 10-10-2013, 09:05 AM   #10
CHRIS67GMC
CHRIS67GMC's Avatar
Re: Wilwood brake ?
67-76 I think is the right one.
