Old 10-07-2013, 05:58 PM   #1
biohazardbill
New Truck... knock in the front end
Usually I am in the 60-66 section of these boards however I found a deal on a truck today I couldnt pass up. The only thing that I could find wrong is the fact that there is a knocking in the front a little bit. I think I remember something about this being a common problem so looking to you guys before tearing into it.
biohazardbill is offline   Reply With Quote
Old 10-14-2013, 12:45 PM   #2
Desert1957
Desert1957's Avatar
Re: New Truck... knock in the front end
Check the "Intermediate Steering Shaft' first, Its sounds like a loose shock or ball joint when bad. The sound and clunk resonate up through the steering shaft into the wheel. Don't let anyone tell you that repacking it with grease will fix it, Replace it.
Desert
Desert1957 is offline   Reply With Quote
Old 10-14-2013, 12:47 PM   #3
Desert1957
Desert1957's Avatar
Old 10-14-2013, 06:09 PM   #4
Special-Ed
Special-Ed's Avatar
mine was replaced once for sure maybe twice...
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 10-14-2013, 06:11 PM   #5
biohazardbill
Ordered one today. Replaced the shocks and ball joints over the weekend. Will let you know how it turns out. Thanks.
Old 10-14-2013, 07:40 PM   #6
onebadbowtie
onebadbowtie's Avatar
also check to make sure your upper control arm bolts are tight. mine worked loose and would make a clunk when hitting bumps or turning.....dang alignment shops
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 10-16-2013, 07:30 PM   #7
clinebarger
Redistributing the grease in the ISS is a very effective FREE...(Though temporary) solution to this.
Separate the Lower & Intermediate steering shafts (Right under the Brake booster/master cylinder). Stroke the ISS in & out several times.....This will redistribute the grease. I do mine once a year.
Pumping grease into it doesn't do much good.
clinebarger is offline   Reply With Quote
Old 10-19-2013, 11:57 AM   #8
biohazardbill
Ok so I got the part in. I used the part number I got from the dealer using my vin. Part number 89023358.
However I think they sent the wrong one unless I am missing something.
Here is the old one in the truck:
New one:
The ends at the u-joint are completely different. Am I missing something here?
Old 10-19-2013, 08:12 PM   #9
clinebarger
The pic of the part on your truck is the Lower Steering shaft.
The Intermediate Steering shaft connects too the Column......(Inside the truck)
