Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-13-2013, 04:57 PM   #1
low&slow
Trailing Arm Project
I heard a lot of you guys welding your trailing arms together in the middle by either yourself or buying plates from various companies. My questions I have:
1. Can I remove the trailing arms from the truck without removing anything else?
2. Should I cut the plug welds, separate both sides, and clean out what rust may be there in the middle? Or not worry about it?
3. Can I just weld right down the middle on both sides of the trailing arms and grind it smooth?
4. After the welds are done, do I need to box it in or can I just leave the sides open?
I'm building my truck to maybe see some track time again. Not looking for low numbers and high speeds, but I know I'm going to end up welding the trailing arms sooner or later. Just trying to find projects I can do to the truck at home without having to buy pieces and parts.
5. Also, along with the trailing arms being out, what gauge of metal should I use to make drop blocks?
low&slow is offline   Reply With Quote
Old 10-13-2013, 11:30 PM   #2
Captainfab
60-66 Nut
Re: Trailing Arm Project
1) You should be able to.
2) I wouldn't go that far unless there is a lot of flaked rust between them. At the very least I would have them sandblasted if you can. That will reveal any hidden issues.
3) You don't want to just weld each side continuesly. You will want to skip back and forth from one side to the other, only welding 3-4" at a time. Also don't just start at one end and start welding. Also skip around on a side from end to end.
4) Boxing them would be optional, depending on just how much power you are planning on subjecting them to.
5) I would use 1/4".......or 3/16" at a minimum.
Old 10-14-2013, 01:21 AM   #3
low&slow
What's the reasoning behind your answer on number 3?
Why skip around with the welds?
Old 10-14-2013, 03:05 PM   #4
70shortwide
too much heat in one place will distort the metal. So when you jump around it gives that area time to cool.
70shortwide is offline   Reply With Quote
Old 10-14-2013, 11:35 PM   #5
Captainfab
60-66 Nut
This is why you want to skip around. Otherwise your trailing arm will end up looking like a banana.
Old 10-16-2013, 12:03 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
Yep, the few sets I've fixed and reinforced for friends and customers, I've only really done stitch welds...I did not completely weld the seam on either side.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-17-2013, 03:21 PM   #7
low&slow
This all makes sense. I think I may just break the plug welds anyways just to make sure they are good on the inside.
Old 11-26-2013, 01:28 AM   #8
RexDodge
Be sure to look closely at the rear for stress cracks like these I found in mine. Clean them or have them sand blasted to be sure you find any issues...then repair!
RexDodge is offline   Reply With Quote
Old 11-26-2013, 07:29 AM   #9
low&slow
Thanks for the heads up. I'll be sure to check them thoroughly.
Old 11-27-2013, 12:15 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here's what I did with my arms.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-27-2013, 09:33 PM   #11
eldogg
eldogg's Avatar
I stitch welded mine.
eldogg is offline   Reply With Quote
Old 11-29-2013, 03:31 AM   #12
RockTonka
RockTonka's Avatar
Stitched welded mine also and made plates for just the outside of each arm...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 11-29-2013, 03:34 AM   #13
low&slow
That's a really nice arm you got there. That's how I hope mine come out.
And thank you all for the info and the pics so far.
Old 12-05-2013, 08:21 AM   #14
PGSigns
PGSigns's Avatar
I have a set of the NASCAR truck arms under mine. The stock ones were not so good so I started to look around for a new set. I got a very nice set for a $100 from a local racer. Heavier gage, stitch welded and with ball swivels in the front. You can find them on ebay also.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-05-2013, 10:01 AM   #15
low&slow
Jimmy
That's not a bad idea. You have any pictures?
Old 12-05-2013, 11:21 AM   #16
70shortwide
I used 2x3 tubing and used a ladder bar cross member to bolt them too. one of the problems with the stock arms is the angle in the back and if your using a stock rearend the pinion angle will get to be too steep if you go real low with it.
Old 12-06-2013, 08:56 PM   #17
low&slow
I was thinking about the pinion angle as well. For now I'm sticking with the original rear end, but when that goes out I'll be upgrading.
Old 12-06-2013, 09:56 PM   #18
JJLT1
JJLT1's Avatar
heres a pics search.. i'v been looking for/at options too.. keep the thread going..
http://www.bing.com/images/search?q=...ms&FORM=HDRSC2
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 06-27-2014, 03:03 AM   #19
low&slow
One other question on the trailing arms, Why are they layed out to be like a triangle and not just straight like the frame?
Old 06-28-2014, 12:40 AM   #20
Captainfab
60-66 Nut
I can't speak for the GM engineers but triangulation helps resist side to side movement
Old 07-10-2014, 07:25 PM   #21
SCOTI
SCOTI's Avatar
Parallel to the frame (rectangle) wouldn't allow as much articulation vs triangulated.
The combination of triangulated mounting, I-beam construction, & rubber lined metal sleeves allowed the solid mounted rear some amount of flex for typical driving.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
