Old 11-03-2013, 09:02 PM   #1
franken
WTB: 32 spline NP203
Sorry, I didn't see a WTB section so here I am.
As the title implies, I'm looking for a 203 to make a doubler to go between an NV4500 and NP205.
If there's a better solution, I'm all ears...
franken is offline   Reply With Quote
Old 11-03-2013, 09:06 PM   #2
snj8198
snj8198's Avatar
Re: WTB: 32 spline NP203
32 spline would be behind the turbo 400. Was the 400/203 an available combo? Also, check Off Road Design's prices on the input shaft change price. It may be easier to buy that then to hunt for such a critter in the wild.
What/who's doubler do you plan to run?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-04-2013, 04:05 AM   #3
andrewmp6
If im reading this right http://www.chuckschevytruckpages.com/73-87specs.html 77-79 k10 k20 and 75-79 k5 blazer used the np203 and the 400 was a option
andrewmp6 is offline   Reply With Quote
Old 11-04-2013, 07:41 PM   #4
franken
Yep, I've noticed TH400 203s are rare.
I'm still undecided on which doubler.
Old 11-04-2013, 08:32 PM   #5
79Betty
79Betty's Avatar
67-72chevytrucks.com/vboard/classifieds/showcat.php?cat=19
That don't work go to the bottom right to forum jump. It's below the 99+ Chevy & GMC Parts Board.
Your wtb section... I have a 350 n 203 combo. How does the doubler work? Seems like more to go wrong?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 11-05-2013, 12:38 AM   #6
Zane M
franken, Where is "somewhere" for a location?
I have a 203 behind a 400, but it isn't going to be worth shipping a far distance price wise.
Zane M is offline   Reply With Quote
Old 11-05-2013, 03:08 AM   #7
andrewmp6
79betty http://offroaddesign.com/catalog/doubler.htm its kinda one and half t cases stuck together and gives you a ratio of 4 to 1 ratio,A stock np205 has a 2 to 1 ratio on it.The other option is a lomax np205 it has a 3 to 1 ratio http://www.jbconversions.com/index2.php?pc=3 its not cheap but its a really beefed up np205.
Old 11-05-2013, 12:33 PM   #8
willett
Another Day, Another Dollar
willett's Avatar
I have a 400/203 in my '78. It's not for sale. They were in trucks until '80. I see them on Craigslist up here pretty frequently
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-05-2013, 12:34 PM   #9
willett
willett's Avatar
Check northwest fab. They make adapters that don't require a 32 spline
Old 11-05-2013, 12:53 PM   #10
snj8198
snj8198's Avatar
Spline count isn't required to run a doubler, it's the strength of the 32 spline combo that a guy is after if a doubler is needed/warrented in the first place. The last thing a guy wants in for the vehicle's fusible link to be buried in the heart of their drive train.
The major difference when choosing between a NWF or ORD adapter is whether the guy wants the 2 piece user clockable ability of the NWF or the simple and arguably stronger one piece design of the ORD.
Steve
Old 11-05-2013, 01:20 PM   #11
obijuan
The input gear is still avail new aftermarket. About 150 bucks. Direct swap with any 10 or 27 spline.
For what its worth, I love my 4500 203 205. I just redrilled rhe face to the round pattern. Ive got a ford 203 that has a round pattern already havent compared gm to ford clocking though.
obijuan is offline   Reply With Quote
Old 11-05-2013, 01:31 PM   #12
Orange Crate
Orange Crate's Avatar
Here are a couple of links for info and parts for a doubler...
http://www.akfabshop.com/alaskaoffroad/tech_2.htm
http://www.quad4x4.com/New_Process_NP205_Parts.html
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 11-27-2013, 04:52 PM   #13
franken
Sorry for the late reply...
If you don't mind parting it, I'm interested in the range box on the front.
I'm in North Texas.
Old 11-27-2013, 07:53 PM   #14
LONGHAIR
Yeah, just so you know....there is a WTB area. It is down the page near the bottom of the Classified section.
Unfortunately, I can't move this there, the format will not allow it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-29-2013, 11:38 PM   #15
franken
Yes, I apologize for misposting. Somehow my addled brain didn't find the WTB section at that time.
I stopped searching for NP203 and just went w/ transfer case and found a few within a reasonable distance. Duh.
It's starting to look like the planetary doubler is about half the price of the NP203 route.
http://www.nc4x4.com/forum/index.php...vetrain.115450
770 ORD NP203 kit
100 NP203
150 32 spline NP203 input
150 Short 32 spline NP205 input
600 Planetary doubler kit
??? Doner TC for kit
??? Shifters
??? Crossmember(s) (actually I have a couple)
??? Driveshafts
32 spline NP203s aren't that common, so while the TC can be found for ~100 (typically 27 spline), the input costs double that.
Similarly, 32 spline short input NP205s aren't common (late SM465 I think), but 205s aren't tough to find (typically 10 spline). Again, the input shaft costs more than the TC.
Anyone have thoughts on the pros and cons of 203 vs planetary doublers? Yes, the planetary is more than a doubler, but for simplicities sake...
np203
