11-05-2013, 09:38 PM | #1 |
Kinked and Bowed Hood
I'm sure if you haven't had it happen to your own square you've at least seen another square with the same problem- a kinked hood. It's a common problem. I was just wondering how you guys fix it.
I've managed to straighten mine out without detaching the hood, and making sure the springs are well greased afterwards- it will do wonders for the hood. But it'll still need straightening after time. The only alternative I've found other than buying a new one or fixing the one you have is a hood brace kit from LMC, for a cheap $20. Has anyone used the kit or have any advice pertaining to this topic? Please help me and many other square owners who have bows for a hood. Check out the kit here:http://www.lmctruck.com/features/cc/cchbk.htm
If It runs like a Chevy, it probably is! |
11-05-2013, 09:53 PM | #2 |
Re: Kinked and Bowed Hood
There's some other threads on here that goes into it a bit.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
11-05-2013, 10:11 PM | #3 |
Watch out for your cornhole !
The hood kinking is actually a safety feature GM designed into the 73-80 trucks.
I usually just spot weld a couple of pieces of flat strap on the bottom side of the hood over the kink points. Its a whole lot cheaper than buying a kit. |
11-05-2013, 11:25 PM | #4 |
Second Chance Program
I have it on my 78 and it stopped the kinking.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
11-06-2013, 12:40 AM | #5 |
I prevented the hood crunch on my 76 by keeping the hinges and big springs lubed - there is a lot of exposed steel there to get rusty even in the desert.
11-06-2013, 08:30 AM | #6 |
I've added plug weld on the sides and steel underneath as well. However keeping it well lubed and when closing, pushing back, then down is a must
11-06-2013, 11:35 AM | #7 |
I put those LMC braces on my "77 so that the hood wouldn't kink. I wrenched in a Chevy dealership in the 70's those hoods would fold when they were new. $20 cheep and easy fix/insurance.
11-08-2013, 11:40 AM | #8 |
dumg question but what did you use ,I used some spray but I think it made it worse
11-08-2013, 08:33 PM | #9 |
I think the owners manual says to use regular motor oil on the hinges. I'm surprised I don't ever see this. I have had about 5 squares over the last 30 years and never kinked a hood. My current truck hood was a little stiff last week and I oiled it. I have kinked a couple of my cutlass hoods years ago and I am sensitive to stiff hinges now.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
11-09-2013, 03:03 PM | #10 |
Moderator
I use Wurth HHS 2000 and spray the whole spring and hinge down.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Tags |
chevrolet, gmc, hood, hood brace kit, kinked hood |
