Old 11-10-2013, 02:55 PM   #1
Chaoszen
Chaoszen's Avatar
Unhappy No Electric Power in 1967 Truck
I got in to start my truck turned the key and nothing happened. Turns out there is no power anywhere except at battery. The starter will engage if shorted at the solenoid. But other than that nothing else works. There is power going into the fuse block but nowhere else. I'm stumped been trying to figure it out for 2 days now. Any advice on how to proceed would be very much appreciated. I was thinking maybe it might be the ignition switch. I'm no electrical wizard for sure. It started fine everyday and then nothing.
Chaoszen is offline   Reply With Quote
Old 11-10-2013, 03:50 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: No Electric Power in 1967 Truck
Do your
headlights work
brake lights
tail lights
horn
When you turn the key on do your
turn signals work
wiipers
heater fan
If they do then you probably have an open circuit in the starter solenoid wire from the key switch. Do you have an automatic transmission?
Check the neutral start switch jiggle the shift lever and try again and try in neutral.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-10-2013, 07:54 PM   #3
Chaoszen
Chaoszen's Avatar
I had no power to all the above you mentioned. Thanks for the reply. Turns out the fuse block is bad. The one on the firewall, it is the original one from 1967 and is in bad shape. A friend of mine bypassed it with a single wire and toggle switch direct to battery for the moment. Now everything works but I will need an updated fuse block which uses the new fuses instead of the old glass ones. Does anyone know the best place to get one? I am going to do an internet search, but if anyone knows of one that might fit I would appreciate it. Thanks.
Old 11-10-2013, 08:15 PM   #4
higgys72
once my 72 did this after getting on the free way had to pull over and call my dad turns out the wire from the alt to the batt or the one from the batt to the ignition switch came loose cant remember which one it was it was a long time ago. but the whole truck went dead no electrical to any thing
higgys72 is offline   Reply With Quote
Old 11-10-2013, 08:47 PM   #5
Chaoszen
Chaoszen's Avatar
Looks like Quickwire has the TR-1400 fuse panel that would serve for $125.00. Has the flashers on the board and room to expand should I need it. Anyone used these replacement fuse panels from Quickwire?
electrical issues
