Old 11-14-2013, 11:48 AM   #1
nascarguy320
nascarguy320's Avatar
6 lug rearend id help
I picked up a rearend that is a coil spring rearend and now im trying to ID the rearend on what gears and what year it is...I did find this on the rearend HA 0410.
nascarguy320 is offline   Reply With Quote
Old 11-15-2013, 02:31 AM   #2
andrewmp6
Re: 6 lug rearend id help
If the diff cover has bolts its probably a 12 bolt or dana 60 http://coloradok5.com/axleguide.shtml that will help you id it,Now if the diff cover has no bolts its a eaton rear end.
andrewmp6 is offline   Reply With Quote
Old 11-15-2013, 12:24 PM   #3
nascarguy320
Its a 12 bolt just trying to find a year and what gears might be in it, it has the drums on it with the factory springs around them and stock steel wheels and old tires too. Was thinking about cleaning it up to sell or use in my truck project.
Old 11-15-2013, 08:18 PM   #4
john
member #16
john's Avatar
HA would be a 3.73:1 for more than one year model if it still has the original gear set.
john is offline   Reply With Quote
Old 11-16-2013, 02:43 AM   #5
nascarguy320
Thanks for the info guys..
