11-18-2013, 10:52 PM | #1 |
69 c/20 rear axle set up
hello i am new to the site and like all the great info thats hear. that being said can anyone give me a direction togo i have a 69 c/20 and the rear diff is a coil under set up how would i go about putting leaf springs on it and a newer axle.i am only thinking about this because i cant find 3.73 gears or lower for the one i have. i think it has 4.56 now but not good for highway use. any help is greatly welcome thx
11-20-2013, 08:13 PM | #2 |
67-72 parts collector,…
Re: 69 c/20 rear axle set up
I think I would keep the coils and just add axle saddles to the newer rearend.
The ride will be much better. You might have to add a new track bar,... like a Super Track bar from ECE.
11-20-2013, 10:48 PM | #3 |
oh i didn't know that i could do that awsome thx. where is a good place to look for something like that?
11-21-2013, 08:44 PM | #4 |
If you are good with a torch or know somebody that is, you can use the ones off the axle in the truck. Take measurements first
11-23-2013, 11:11 AM | #5 |
4.10 is the tallest gear you can get for an Eaton rear. If you can find a coil sprung Dana 60 then you can get 3.54. Not near as common as the Eaton in coil spring however, but they are out there.
11-23-2013, 12:47 PM | #6 | |
www.earlyclassic.com They have new axle saddles and a Super Track Bar to center your late model rearend.
11-26-2013, 07:39 AM | #7 |
AWSOME thx for the info. While I'm working on the rear dose anyone know. if I put a drop spindle in the front can I use the coils or do I have to put air bags in ??
11-26-2013, 07:40 AM | #8 |
And are 1/2 ton spindles the same as 3/4 ton spindles ??
11-26-2013, 08:36 AM | #9 | |
No. They are different. Different upper and lower balljoints, different outer tie rods and different lower a-arms.
11-29-2013, 11:37 PM | #10 |
Thx for all the info Keith. I got a hold of ece and they are AWSOME people. You wouldn't know if I have to keep my two piece drive shaft or should I try to switch it over to a one piece when I redo the drive train set up ??
