hood doesn't open
When I lift the hood release on my 71 C20, the hood does not pop up so I can get under it and lift. The guy who had it before me put a new hood on. Is it possible he forgot a spring or something that pops the hood?
Walt |
Re: hood doesn't open
hey knight 61 i see your in reading!
cool another local on here ![]() i grew up in reading but its no place too raise a family and have some security so i got out. welcome aboard missalingment of the hood and or latch lack of lube on the latch and hood hinges
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Carpe manana
![]() ![]() Join Date: Dec 2010
Try adjusting the height of the rubber stops on the radiator support, that may help.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
lots of times just loosening up the mounting bolts on the latch will solve that type of problem// it is also a good idea to spray the crap out of it to remove petrified grease and they a nice coating of freash grease for good operating
Take a power saw and cut out the front center of the hood. Problem solved. Seriously though, the fix is most likely as cdowns suggested, or the hood hinges are done.
the boat guy
its a chevy why would you need to open the hood?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
To show off the engine of course.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
![]() Join Date: Oct 2009
usually an indication of worn springs. do what cdowns mentioned and, if that doesn't help, might be time for new springs. Strange thing - I had my hood hinge disconnected from the fender for a bit - when I reconnected it all back up, the hood wouldn't pop back up when released. Some fine tuning, and it actually still had enough spring in the springs to pop it.
Is your release mechanism releasing it, but it's just not popping up a bit? Or, is it not releasing at all? |
The Older Generation
Get a plastic door panel tool or a plastic glass installation tool and see if you can pry the hood up while you pull on the release handle... LockDoc
![]() Join Date: Oct 2013
I had a thread going here with the same problem on my '68 C10. Turned out someone had put a '69 lower hood latch in - would not move at all with pressure pushing down while pushing on release latch, etc. because of the '68 grill style I was barely, with lots of pain, able to remove the bolts and open the hood. I used small wedge shaped pieces of wood to move hood up as far as it would go while I worked on it. look on eBay for hood latches to compare what you have with correct one for your truck. let us know how you fixed it.
I would say more than likely just the latch and or pin is out of alignment. the pin on the hood should be centered going into the latch. or your hinges are kaput. Good luck!
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
also, under surface of lower hood latch plate is a return (?) spring that sometimes breaks too. so, latch catch arm will not work properly. again, look at pictures in hood latch ads on eBay
#13 |
![]() Join Date: Jan 2007
my 70 hood was not opening. i was able to get a screw driver in from underneath and slide this mechanism over and it opened.
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#14 |
Thanks guys for all the suggestions. Lubing all the moving parts on the hinges and latch assembly did the trick. An easy fix, problem solved.
Walt |
#15 |
"Trucks with Class"
![]() Join Date: Jul 2000
Have you seen this one? A simple solution to a common problem!
http://67-72chevytrucks.com/vboard/s...ht=hood+popper |
#16 |
so how did you get the hood open to lubricate everything?
#17 | |
#18 |
I always could open it with prying it up with a screw driver. When I lifted the release, the hood did release, it just did not come up enough to get my fingers under.
#19 |
