11-23-2013, 04:54 PM | #1 |
Valve covers
Hi everyone,
Would anyone know of a set of aluminum valve covers that taper back in the front like these stock ones? Whoever put in the after market A/C pump has it mounted so close that I don't think straight up valve covers will work. The A/C pump could be moved but it would be a royal pain. Thanks, Tom
1970 C-10 350, 350 trans, ps,pb |
11-23-2013, 05:23 PM | #2 |
Re: Valve covers
I dont know of one by brand, But, Id look on ebay----they seem to have every valve cover known to man!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
11-23-2013, 09:00 PM | #3 |
Re: Valve covers
Could you maybe get a longer belt to allow to tilt away more?
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
11-23-2013, 09:37 PM | #4 |
Re: Valve covers
Got my aluminum retro finned from here. They are awesome. http://kmjent.com/catalogsearch/resu...e+covers&top=1
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
11-23-2013, 09:47 PM | #5 |
Quit if it's not FUN!!!
Re: Valve covers
11-23-2013, 09:59 PM | #6 |
Re: Valve covers
don't know if these will work, but I have them for sale. They're brand new and have been coated with Nyalic to keep them looking new.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-23-2013, 10:18 PM | #7 |
Re: Valve covers
When looking at aftermarket V/C's if your able[and you are because it has the stock ones] short V/C's are the way to go. Because in the specs or ads for the ones the the shops list most all say will clear air or not. Jim
11-23-2013, 11:14 PM | #8 |
Re: Valve covers
vette aluminum finned valve covers are cast aluminum and should have a similar slant. Originals not cheap, but repops are reasonable. Oh, and they are cool
if you shop for used ones, keep in mind you need to make sure that they are not the "staggered hole" type (i.e. from when the sbc had uneven mounting holes for the valve covers - they were closer together on the top). You'd want the non-staggered type. I believe they were 7-fin covers. |
11-24-2013, 09:41 AM | #9 |
Re: Valve covers
Thanks for all the info I'll check some of these out. I could put on a longer belt but that would be a last resort because the mounting plate would have to be extended as well as both compressor braces.
Tom
11-24-2013, 09:48 AM | #10 |
Re: Valve covers
Have you thought about powder coating the ones you have?
11-24-2013, 10:12 AM | #11 |
Re: Valve covers
I have but they're so thin that I can't get them to quit leaking. I removed the old oil saturated cork gaskets and replaced them with the expensive Felpro Perma Dry Plus ones and they still leak. They're not warped but you can't over tighten them or they'll leak worse. If I can't find an aluminum set I may have to use the right stuff to seal these.
Tom
