Old 11-24-2013, 10:31 PM   #1
*71SWB*
Is this what I need
I have a 71 swb that has a 69 camaro 350. I want to replace the stock type fuel pump. Will this work;
Summit Racing part # EDL-1721
1969 CHEVROLET CAMARO Edelbrock Performer RPM Street Fuel Pumps 1721
Edelbrock 1721 - Edelbrock Performer RPM Street Fuel Pumps
Fuel Pump, Mechanical, Performer RPM Series, 6 psi Maximum Pressure, Chevy, GMC, Small Block, Each
Part Type:
Fuel Pumps, Mechanical
Application:
Find out if this fits your application
Email Email
Overview
Applications
Suggested Parts
Related Kit/Combos
Show All
Instructions
Brand:Edelbrock
Manufacturer's Part Number:1721
Part Type:Fuel Pumps, Mechanical
Product Line:Edelbrock Performer RPM Street Fuel Pumps
Summit Racing Part Number:EDL-1721
UPC:085347017218
Free Flow Rate:110 gph
Maximum Pressure (psi):6 psi
Inlet Attachment:Female threads
Inlet Size:3/8 in. NPT
Inlet Quantity:One
Outlet Attachment:Female threads
Outlet Size:3/8 in. NPT
Outlet Quantity:One
Quantity:Sold individually.
Notes:These fuel pumps are capable of supporting up to 600 horsepower.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
Edelbrock Performer RPM street fuel pumps are designed for use with all Edelbrock carburetors used in Performer or Performer RPM applications. These high performance street fuel pumps feature a high-quality, 3-stage polished finish. The unique valve design of these pumps improves flow quantity and quality and will support engines with up to 600 hp. The high-volume, 3/8 in. NPT inlet and outlets surpass the capacity of many other pumps. Edelbrock Performer RPM street fuel pumps produce 6 psi and do not require a regulator. Best of all, the clockable lower housing can be rotated for the best inlet and outlet alignment. They are designed for use with gasoline only.
*71SWB* is offline   Reply With Quote
Old 11-24-2013, 10:56 PM   #2
Lattimer
Lattimer's Avatar
Re: Is this what I need
Part Type:
Application:
Email Email
Overview
Applications
Suggested Parts
Related Kit/Combos
Show All
Instructions
Brand:Edelbrock
UPC:085347017218
Inlet Quantity:One
Outlet Quantity:One
What carb are you running? The Edelbrock carbs like low pressure, so their pumps are designed for that.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-24-2013, 11:09 PM   #3
kcsa75
kcsa75's Avatar
Yes.
Why do you want to change fuel pumps?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-25-2013, 09:58 AM   #4
cdowns
cdowns's Avatar
lots of guys waste lots of money reading catalogue hype when the factory original fuel pumps that worked just fine for 40+ years are what is required
Old 11-25-2013, 10:13 AM   #5
Lee H
Lee H's Avatar
The Stock pump from your local auto house will support your "needs". That pump will support your wants.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
