Old 11-25-2013, 08:59 PM   #1
TACwelds
TACwelds's Avatar
wing window rebuild
Help please, does any one know of a good thread for rebuilding wing windows for 55 thur 59
TACwelds is offline   Reply With Quote
Old 11-25-2013, 10:27 PM   #2
Daze57
Daze57's Avatar
Re: wing window rebuild
its not that hard sir i can help
Daze57 is offline   Reply With Quote
Old 11-25-2013, 11:38 PM   #3
TACwelds
TACwelds's Avatar
thanks Daze57 I took them apart 2 years ago and I have all new gaskets and rivets but have not seen them in one piece for awhile some pics would be nice
Old 11-25-2013, 11:49 PM   #4
Daze57
Daze57's Avatar
Ok
well first get all your parts together. Than figure out what ya need.
Then tell us how far they are broken down.
What kind of shape is everything in?
From there we can help ya get it together.
Do you have new rubber for the vent window?
And is the old stuff out? do you have the window out of the frame?
Old 11-25-2013, 11:54 PM   #5
Daze57
Daze57's Avatar
Just asking to see where you are at with all this.
Old 11-26-2013, 10:39 PM   #6
TACwelds
TACwelds's Avatar
thank you Daze57 for your response here are some pics of where I am my questions are paint or powder coat pros and cons, is dish soap best for glass installation, are the solid rivets the best or do pop rivets work.
Old 11-26-2013, 11:09 PM   #7
Daze57
Daze57's Avatar
OK good ?s .
dish soap and warm water is best foer the rubber - douse in the water real good and then press in to place ,
use the factory rivits -pop rivits leave too much extra material on them
looking at you stuff you have it all looks good .
you can if you are careful separate the wing window from the frame
if you pull up carefully on the top of the frame you will be able to clear the top pin from the frame .
then add your rubber and put it bk together the same way .
Old 11-26-2013, 11:10 PM   #8
Daze57
Daze57's Avatar
i will get bk to ya
Old 11-27-2013, 12:16 AM   #9
Daze57
Daze57's Avatar
Make sure you have "window setting tape" for the wing window itself.it goes along the back of the wing widow evenly all the way down the back of the glass then push it into the frame evenly
As far as powder coat ....I did my entire frame ....came out nice.
I am sure paint would be nice but I just like powdercoat
Old 11-27-2013, 12:21 AM   #10
Daze57
Daze57's Avatar
When you do your rivits! Do you have the rivit setting tool? If not check to see if the place where you got rivits has the tool ..make sure you put them in straight ....take your time!!!!
Old 11-27-2013, 12:22 AM   #11
Daze57
Daze57's Avatar
Holla if ya got more? S
Old 11-27-2013, 07:41 PM   #12
Daze57
Daze57's Avatar
also check 'stove bolt.com '' they have an article on rebuilding an earlier vent window - but the process is just about the same . good picts also
the article is v well done
