Old 11-26-2013, 09:20 PM   #1
bikernut
bikernut's Avatar
Dome light
on my 2003 3500 4X4, standard cab, base model the dome light used to work. It has stopped working but will come on when I use the dash rheostat to turn it on and put the truck in reverse it turns on. I have looked to see if I had a blown fuse but didn't find one for the dome light, and I know from past experience that is an indication that something is wrong but I haven't found it. can anyone shed any light as to where I might now look. thanks for any help
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 11-27-2013, 01:27 AM   #2
83GMCK2500
Re: Dome light
Did you bump the Dome Override switch next to main light switch?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-27-2013, 05:15 AM   #3
bikernut
bikernut's Avatar
Re: Dome light
no, I tried that but it still didn't work and as I said it works when I put it in reverse and years ago when a fuse blew out or something like that it would put the dome lamp on when you closed the door and shut it off when you opened the door so I figured it might be something like that happening.
Old 11-27-2013, 06:32 AM   #4
463
463's Avatar
Re: Dome light
Have a look in the driver side fuse box. there is two 15 amp fuses that feed the BCM called TBC 2C & 2A for the dome light for a start. Then in the under hood fuse box there is a 10 amp TBC battery fuse that feeds the BCM.
The shift in to reverse tends to point a back feed from a poor ground.
If there is a trailer plug there may damp dust in the plug or bad wires causing a back feed.
Trueman
463 is offline   Reply With Quote
Old 11-27-2013, 06:35 AM   #5
bikernut
bikernut's Avatar
Re: Dome light
I will take a look at it as soon as it stops raining here in NH.thanks
