11-29-2013, 10:30 PM | #1 |
may i ask for your pic?
Hey guys,
I'm wanting to purchase sway bars for my truck. I'm wondering if I could get some input and pics of how there mounted up? Maybe even the difference between a 64 like mine and a 64 with the 68-72 front suspension? Also, in the rear I have a ford 9" and leaf springs flipped under instead of coil springs and trailing arms, so with that in mind what rear sway bar would work best? She doesn't really lean much but I feel it would tighten things up and I loved the difference when I added them to the nova. Pics might also help me determine exactly what front suspension components I have. Thanks for your time guys. It does have power steering/brakes and I thought drop spindles but I'm not positive.
Live and let live |
11-30-2013, 09:35 PM | #2 |
Re: may i ask for your pic?
I don't have pics of mine as my truck isn't even running yet but a lot of guys are running the stock 1.25" front bar from the 73 - 87 trucks. The C20-C30 have these bars and even the smaller bars will bolt right on using stock mounting hardware.
As for the rear bars, the 82-92 Camaro/Firebird bars will work but I'm not sure about the leaf spring trucks. Here's the original write up showing it so maybe you can check it out and compare it with yours to see if it will or not. http://www.low69cst.freeservers.com/CamaroBar.htm
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
11-30-2013, 10:29 PM | #3 |
Thanks bud
Live and let live |
