Old 12-01-2013, 05:44 PM   #1
lowrodderchev
lowrodderchev's Avatar
stupid fuel gauge
hey guys ive researched trouble searching on fuel gauges but this ones got me twisted. 6 months ago I put a new sending unit in my blazer. so I could see how much gas I had well recently it started to mark 1/2 no matter what was in the tank. and every so often it would mark correctly and then go back. well the last 5 days its just stayed on 1/2 tank. i know i have at least 3/4 tank. i switched the fuel gauge and same thing. any ideas? i bought the sending unit at oreillys they aint to fun to put i either LOLthanx
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 12-01-2013, 05:58 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: stupid fuel gauge
I'd suspect the sending unit again. The new floats are garbage.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-01-2013, 06:21 PM   #3
lowrodderchev
hooray so those stupid things only last like a half a year dam what a waste of money and broken knuckles
Old 12-01-2013, 06:28 PM   #4
lowrodderchev
oops I just called oreillys I guess ive had it a year and 2 months now dam throw away parts.
Old 12-01-2013, 07:01 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Went through that sending unit issue with the bad float on a 68 last year, replaced it twice and the new junk wouldn't work a day. It would be nice if you could spray them with something to seal them that wouldn't dissolve in your gas and foul it up.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-01-2013, 08:00 PM   #6
lowrodderchev
was reading on another website were guys just cut a access hole in the bed instead of removing the whole tank. this sucks cause I really enjoyed having a fuel gauge
Old 12-08-2013, 12:47 AM   #7
augwld
Not discounting new equipment being junk, but did you check your grounds. My '79 K10 used to read 1/4 no matter what. I installed a new ground from tank to frame and the gauge has been reading true ever since. With any electrical issues,gauges incl., 90% of the time a ground is the culprit. Cheap fix first.
augwld is offline   Reply With Quote
Old 12-08-2013, 10:26 AM   #8
lowrodderchev
Thanx I'll check that out funny thing it started marking a little less than 1/4 of a tank and it was right but after a fill up back to the center it went
Old 12-08-2013, 04:47 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
for sure check the tank/sender ground.may even want to add one for the cluster
i bought a spectra sender last year for the 79 no problems
and it sat 5 months over the winter,parked again now
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
