12-07-2013, 02:52 PM | #1 |
cab mount location..
looks like i need help yet again...i looked over the site and couldnt find anything about this...not to say its not around...anyways i got a cab mount set and installed it ..3 mounts per side..three dif heights. looks to me like it starts with the shortest from the front and and the middle size next ..then the thickest mount at the back of the cab???? is this right because my cab looks high in the front. and its not helping to line panels up. again thanx for the help.
12-07-2013, 05:15 PM | #2 |
Re: cab mount location..
Hope this helps. All 4 cab mounts should be the same size. Once the cab is squared up, you may need some shims (washers) to raise the radiator support a bit (not always, but sometimes.)
http://67-72chevytrucks.com/vboard/s....php?p=1636290
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-07-2013, 05:30 PM | #3 |
He mentioned 3 per side ?
71 C-20 07 Magnum RT AWD |
12-07-2013, 07:28 PM | #4 |
Yeah, I think he meant 2 cab and 1 for rad support (per side.) But again, all 4 cab "pucks" should be the same size! So I'm not sure why he has 3 different sizes?
cab: Rad support:
12-07-2013, 10:33 PM | #5 |
this is the set i have
12-07-2013, 10:35 PM | #6 |
they are not all the same size.. do i have the wrong kit?
12-07-2013, 11:25 PM | #7 |
I'd say you got it right. Did you have shims on the front radiator support? Somebody might have shimmed it up as the bushings got weak.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
12-07-2013, 11:59 PM | #8 |
no shims.. is this kit the only thing that goes from frame to body? im not missing parts?
12-08-2013, 12:03 AM | #9 |
i have seen some mount kits that look nothing like the one i have .they have a what looks like 3inch rear mount..whay are some one way and others not?
12-08-2013, 12:21 AM | #10 |
ok hold up is this all because its a 4x4? lol is that whats up? dif mounts for 2 wheel and 4x4?
12-08-2013, 12:41 AM | #11 |
Forgot about that... I seem to recall reading on here 4x4's do have different mounts.
Edit: Looks like 4x4 kits do have different size mounts: http://www.summitracing.com/parts/pt...FRBnOgod0isAWQ
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-08-2013 at 12:47 AM. |
12-08-2013, 01:17 AM | #12 |
after a good long look..looks like the 2wd mounts and the 4x4 mounts are not the same.i hope this helps anyone that comes across this problem.thanx everyone.
12-08-2013, 12:43 PM | #13 |
So did you get the wrong mounts? Whomever sold them to you should offer to send you the correct ones. Glad it's all figured out now!
12-08-2013, 01:10 PM | #14 |
Can you add pics of the install positions to help others that will face this very issue in the future........Thanks!
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
12-08-2013, 02:14 PM | #15 |
I used the energy suspension kit on my 72 .the radiator support mounts are unique. the four cab mounts, instructions said to use the taller ones in the rear yet I had to swap them to the front to get my fenders to door gap right .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Tags |
body mounts, cab mounts, mounts |
