Old 12-11-2013, 01:42 PM   #1
elf w/capital T
Question 68 SWB aftermarket crossmember question
I can get a deal on one of these...'below' but before i make the drive and spend the cash.....quick question...
It says for a 5inch drop or more... my new rear springs will be a 4inch drop... i have a one piece driveshaft, 3inch in diameter... WILL THERE BE AN ISSUE with the clearance with NOT having the 5inch or more drop??
Thanks!
elf w/capital T is offline   Reply With Quote
Old 12-17-2013, 08:33 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 68 SWB aftermarket crossmember question
Do you have a link to what you are talking about,... "below"?
Keith
Convert to disc brakes.
Old 12-18-2013, 03:26 AM   #3
elf w/capital T
http://www.performanceonline.com/196...pension-19834/
yikes, i can't believe it took that long for someone to ask! i feel like a tard! thanks man lol
Old 12-18-2013, 08:56 AM   #4
lolife99
lolife99's Avatar
It's basically a copy of the ECE trailing arm crossmember.
Wish I could help but I have never used this product.
I prefer the round tube design that www.porterbuiltfabrication.com sells.
Keith
Old 12-18-2013, 10:45 AM   #5
SCOTI
SCOTI's Avatar
I've used the ECE x-members & they allow about 3/4" additional clearance vs the OE x-member.
For reference, my 68 was about 7-8" of rear drop (bags bolted directly to the frame & T/A's + 1.5" lowering blocks). I didn't have any clearance issues w/a 1pc shaft (3"OD) & the OE x-member.
I've got my current 64 set-up w/the ECE x-member, front Porterbuilt Dropmember, PB 3" dropped T/A's, & again using a 1pc/3"OD OE driveshaft . I had to increase the height of the ECE unit 2" to keep from interference @ full drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2013, 12:29 PM   #6
elf w/capital T
Thanks Scoti!
