Old 12-11-2013, 06:46 PM   #1
Plunkett
87 v1500 heater question
So I've been having problems with the heater in my truck. The first problem was that it wouldn't blow hot. I replaced the thermostat with a 195degree piece, the heaters hoses going to the heater core are hot. I finally noticed that the cable that controls the temp has a broken tab which isn't fully shutting the blend door. My other problem is that I have air blowing out all the vents when the defrost is on. I noticed that the rod coming over that actuated the change from defrost to heat doesn't move at all. Is it just a cable that I need to replace to fix that problem or what?
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires.
Plunkett is offline   Reply With Quote
