12-12-2013, 01:34 AM | #1 |
First year for xtra speedo digit
What year did the extra digit on the odometer start?
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
12-12-2013, 01:56 AM | #2 |
Re: First year for xtra speedo digit
I believe it was at the same time they went to the electric (instead of cable driven) speedometers ... 1990 & 1991 R/V series.
12-12-2013, 01:58 AM | #3 |
It was in 1990 they started doing that on the R/V series trucks. Already the C/K series (88-98) had the extrab digit.
12-12-2013, 02:02 AM | #4 |
My 83 has a 6-digit odo but I know my speedo has been replaced...twice I think. I've seen several mechanical 6-digit odo speedos.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
12-12-2013, 10:23 AM | #5 |
It was at least 85, maybe before.My 85 has 6 digits & it's original speedo.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
12-12-2013, 11:00 AM | #6 |
My 86 C10 has it's original 6 digit speedo. I also have an 85 C60 speedo with 7 digits.
12-12-2013, 01:07 PM | #7 |
Is there a difference from miles vs kilometers?
I'm only aware of the 1/2, 3/4 ton pickups, Blazers, Suburbans having 5 digits (no 100,000 number) up to 1989. And then 1990 on up had the extra digit. This goes for the R/V series in the 89-91 era.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
12-12-2013, 01:15 PM | #8 |
No. Within the specific cluster housing there is no architectural difference; only labeling and calibration.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-12-2013, 01:36 PM | #9 |
1985 C60 speedo, cable drive type.
Not sure if all big trucks of that era had them. |
12-12-2013, 05:53 PM | #10 |
78K & 79C Jimmys
My Suburbans were
my 87 i believe was 5-in kms 88 is 5- in miles 89 is 6-in kms I used the 87 cluster for quite a while was plug and play
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-12-2013, 08:01 PM | #11 |
Doing some research on this and it appears that the years were all over the place. I would have thought there would be a specific year this took effect but appears not to be.
12-12-2013, 08:18 PM | #12 |
[quote=MalibuSSwagon;6414800]1985 C60 speedo, cable drive type.
Well, I've got to say that I certainly learned something new from this thread As I posted above, I always thought they added the extra digit when they went to electric speedometers. After seeing this one you posted, I took a look through my stash of spare parts. And sure enough, I found a couple of medium duty clusters with cable drive speedometers that have the extra digit in the odometer just like yours. They were both the 80's style 85 MPH speedometers. I have yet to see an older 70's style 100 MPH speedometer with the extra digit though. So there's a good chance that most (if not all) of the big trucks had the extra digit starting sometime in the early 80's. I'm still curious about the 1/2, 3/4, and 1-ton trucks though. I guess speedometer swaps (from medium duty trucks) could account for some of them. And I wouldn't be surprised if some dealer-installed GM service replacement speedometers had the extra digit too. |
12-12-2013, 09:03 PM | #13 |
78K & 79C Jimmys
not sure when, but I've wondered if we did the 6th first in Canada cause Km go faster then miles
12-13-2013, 08:26 AM | #14 |
My 87 V20 has the 5 digit odometer.
12-13-2013, 10:51 AM | #15 |
^^^ this is what I was thinking.
12-13-2013, 08:22 PM | #16 |
my 88 v30 has the 5 digit. its been turned over twice since i've owned it!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
