Closed Thread
Old 12-12-2013, 01:35 AM   #1
Blue Heeler
Blue Heeler's Avatar
How do you install rubber door plug.
I have a 65 c10 and i have posted how do you install the black nipple in the door jam, does anyone have a great solution for this? have tried many times with no luck. i have a chick that can help me so thats not the problem. thanks.
Blue Heeler is offline
Old 12-12-2013, 11:36 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: How do you install rubber door plug.
You need lots of lube and push it in really hard. :p
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 12-12-2013, 11:58 AM   #3
forcedinduction
forcedinduction's Avatar
Warm it up with a heat gun, spray some silicone on it and push. The very tip of the bumper will go through the hole. Try working the rest through using a tiny screwdriver or pick. Once you have some of it through, grab it from the back with a needlenose pliers and work it some more. Reapply silicone lube as needed.
forcedinduction is offline
Old 12-12-2013, 12:26 PM   #4
oem4me
You mean the anti-rattle bumper thingies? Isn't there a hole in the center of the bumper to insert a poker tool of some kind? When you push on the tool it will stretch the bumper lengthwise, reducing it's width allowing it to pop into the hole in the door jamb. Also, use a lube that will dry out and not stay slippery or it will be prone to popping out. If this is not what you are talking about, never mind.
oem4me is offline
Old 12-12-2013, 12:41 PM   #5
63burban
Chevy addict
oem4me is on the right track, I have one of those tools, will try to get a pic of it later. It is a blunt punch looking tool with a shoulder that pushes against the outer edge while the pin stretches the pointed tip into the hole.
63burban is offline
Old 12-12-2013, 12:53 PM   #6
oem4me
They've got specific tools for every job, I guess ... I think I just used a skinny allen key.
oem4me is offline
Old 12-12-2013, 03:39 PM   #7
sodly
sodly's Avatar
By the way, can you pull one of these out (of a salvage truck) to reuse? I need one and figured I'd just pull one out of an old truck sometime. Or am I wasting my time trying that?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline
Old 12-12-2013, 04:18 PM   #8
ACK
ACK's Avatar
There's 2 sizes, I think they changed in mid- to late 1964. The end that pops into the hole is larger for the later years if I remember correctly. I had to drill the holes out to make them fit my truck.
My truck ain't dead, it just smells funny.
ACK is offline
Old 12-13-2013, 01:04 AM   #9
Blue Heeler
I bought these plugs at the truck shop and honestly i think i have to drill out the hole. i have boiled water, used a heat gun and nothing works.
Old 12-13-2013, 09:52 PM   #10
luvbowties
luvbowties's Avatar
Thumbs up Re: How do you install rubber door plug.
Good ideas re: heat. Also use lube. Then use a punch-looking "line-up" tool (with a blunt end...see pic below)and push thru the outer hole in rubber, wobbling end of punch as you push/work tip into-and-thru hole. May hafta use a blunt-ended small screwdriver to help it along. BUT: they can be installed this way--I know, as I just put them in my '66. Not easy; just use patience.
Sam
luvbowties is offline
Old 12-13-2013, 10:11 PM   #11
Blue Heeler
I tried the punch will make hole a bit bigger and try again.
Old 12-13-2013, 11:19 PM   #12
wjjeeper
wjjeeper's Avatar
Don't know what rubber plug you're taking about but that brunette is awesome.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline
Old 12-14-2013, 01:11 AM   #13
luvbowties
luvbowties's Avatar
Smile Re: How do you install rubber door plug.
Well then, why not just use the punch & drive the tapered portion into hole & just "flare" the opening, slightly, to make tit start sliding thru easier? [May hafta grind off/shorten punch to get to the flared portion sooner.]
Sam
Old 12-14-2013, 10:18 AM   #14
sigshooter
sigshooter's Avatar
Punch, what punch?
Oh there was talk about a punch in this thread, I had to re-read it about 30 times....... Lol
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline
Old 12-14-2013, 11:33 AM   #15
Blue Heeler
Edited by Forum Staff
Okay guys, enough. Keep it family friendly or it gets closed
Old 12-14-2013, 11:48 AM   #16
wjjeeper
wjjeeper's Avatar
Oh snap!
wjjeeper is offline
Old 12-14-2013, 11:51 AM   #17
LT1 Burb
LT1 Burb's Avatar
I used dish washing soap and it slid right in!
LT1 Burb is offline
Old 12-14-2013, 12:15 PM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'd really rather this forum stay the way its been in regards family friendly.
No this isn't nudity, but I tell my wife this forum isn't lowrider magazine. A sexist magazine.
There's young ones that enjoy this forum with their dad building trucks - father and daughter projects.
66 C20 Service Truck:
LostMy65 is offline
Closed Thread
