12-16-2013, 01:04 PM | #1 |
Laying cab on rear window
I've just completed all of the metal work (inner and outer rockers, cab corners, partial floors) on my 64 C10 project. I want to clean-up the underneath of the cab and give it a fresh coat of paint before I put it on the dolly that I plan on building to move it around my garage. My question is; can I safely lay the cab on the back window so I have easy access to the underneath? I plan on laying it on a sheet of plywood with a 2-inch foam pad between the cab and the plywood. The cab is not painted, so I'm not concerned about scratching the paint but I dont want to "tweak" or "bend" anything by placing it in this position.
Thanks in advance...............Dan |
12-16-2013, 02:02 PM | #2 |
Re: Laying cab on rear window
Is it small or large window? I would pull the glass. But a couple 2x4 outside the glass would work. The slightest tweak could pop the glass. Tilt cab back just enough not to touch glass.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
12-16-2013, 02:28 PM | #3 |
The cab is fully stripped, no glass, no doors, no seat.........just the bare shell. I'm assuming that 4 guys should be able to lift it from the frame and gently lay it on it's back? I just down want the weight of the cab to bend or twist anything when it is laying in this position.
12-16-2013, 02:46 PM | #4 |
It should be fine. 4 Minnesota boys should be able to handle that.
12-16-2013, 03:42 PM | #5 |
12-17-2013, 01:05 AM | #6 |
I've got mine on its back right now doing just that. Stripped, epoxy primer, and Raptor bed liner.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
12-17-2013, 01:41 AM | #7 |
64-66 CHEVY JUNKIE
Man pdxhall that looks really Good !!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
12-17-2013, 02:38 AM | #8 |
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-17-2013, 07:42 AM | #9 |
I'm glad you asked this. I am planning on doing this as soon as my rockers and floorpans are all fixed. I want to do my just like PDX's
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
