Old 12-18-2013, 07:47 AM   #1
R_W
R_W's Avatar
Need help with heat, children are freezing!
OK so I rebuilt the heater, new core, new hoses, new motor, new fan. Flushed radiator. Coolant is full, new 195 thermostat. hose attachments match diagrams posted. Late 70's 350.
I attempted to burp the heater core by pulling off the outlet hose and letting the truck warm up. When the thermostat started to open, a weak flow came out, then would stop. Then a little more, then would stop. I kind of expected a steady flow...
Anyway, fan works, blows right direction, but always blows cold. Air box flapper works. Inlet hose gets hot, outlet hose never seems to get hot. It is acting like it still has an air lock, but not sure.
3 core radiator, system cools really good, even on hot days in summer.
Is it too cold for my thermostat to open up enough?
And just in case DCS is cruising the website, I do not drive the children around without car seats
______________________
"Daddy, that truck's not red"
Build Thread: TN 20 Build
R_W is offline   Reply With Quote
Old 12-18-2013, 08:34 AM   #2
donthekawguy
donthekawguy's Avatar
Re: Need help with heat, children are freezing!
Try pulling the core out and filling the inlet with anti freeze then plug the hole with your finger while you warm it up. Sounds like you have a stubborn air pocket.
66 shorty
donthekawguy is offline   Reply With Quote
Old 12-18-2013, 08:36 AM   #3
awbrown
you are not getting any flow through the core , post a picture of how your hoses are routed and where they hook up to the engine .. if you have a new core (brand new not used ) then your problem is else where .. both tubes on the heater core should be hot ,if only one is it has to be a flow problem .. you should not have to "burp" the heater core because flow will start the minute you fire the engine ,the line coming from the water pump will have more than enough pressure to flush out any air in the heater core.. 2 more things to think about , do you have a temp gauge on the vehicle??? are you sure your thermostat is working properly???
awbrown is offline   Reply With Quote
Old 12-18-2013, 08:42 AM   #4
awbrown
Oh do you have the deluxe heater or the one mounted in the truck cab ??? My 63 has the original heater core , the one that has the valve on it (the 4 control as oposed to the 2 control) I had to make sure the valve on the heater core was open , they don't often work properly so you depending on which core you have it is one more thing to check...
Old 12-18-2013, 08:58 AM   #5
tincan1966
tincan1966's Avatar
The 5/8" heater hose from the intake manifold near the thermostat is the supply to the heater core, the 3/4" hose to the water pump is the return.
It also depends on which intake manifold gaskets you have installed, and could be installed incorrectly. Later model engines(the center bolt valve cover ones) draw the heater supply from the passenger side REAR corner of the intake manifold and return from the core to the radiator. These engines use a different intake gasket than the older V8's, and have a restrictor installed.
Something you can do is install a "flush T" in the 5/8 hose and fill the core that way, or remove the 5/8 hose from the core, install a short length of hose to the core and fill it that way,with the radiator cap on and tight, then reconnect your hose from the intake to it. It is completely possible to have aire trapped, since the core is about 6" above the radiator neck
tincan1966 is offline   Reply With Quote
Old 12-18-2013, 10:11 AM   #6
R_W
R_W's Avatar
Here is the routing, new heater core. There is an interesting port plugged on the manifold that is circled in the photo above...
When I got it there were no heater hoses, both ports I am using were plugged.
Old 12-18-2013, 10:36 AM   #7
tincan1966
tincan1966's Avatar
Your problem is the only water you will get to the core is going to be after thert-stat opens. I would move that hose to the plugged port on the front passenger side of intake, that you have circled. You will have continuous water flow then. That is the supply to the core. You can plug the hole in the top of the t-stat housing.
The other routing looks correct and should work fine.
Hope that helps. Good luck! and thanks for posting pic, it explained your setup well.
Old 12-18-2013, 10:45 AM   #8
1963c-10
1963c-10's Avatar
x2....move to the plugged port
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-18-2013, 11:15 AM   #9
R_W
R_W's Avatar
Thanks guys, I'll give that a go tomorrow and post results
Old 12-18-2013, 11:43 AM   #10
1963c-10
1963c-10's Avatar
With any luck, the plug that you remove will fit the thermostat housing to plug that port.
Old 12-18-2013, 02:54 PM   #11
jtrichard
the old saying goes a picture is worth a thousand words is so true........ the port you have used is for smog crap and you wont get any flow to the heater until the stat opens and then VERY LITTLE as said above move the 5/8 to the plugged port you have in red square and it should roast you out of the cab then you will hear "its to hot" LOL
jtrichard is offline   Reply With Quote
Old 12-18-2013, 05:29 PM   #12
RANDY COX
RANDY COX's Avatar
Yep x3 I know the one in my truck after it warms up it gets so hot It'll burn you best heater I've had in an old truck..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-18-2013, 07:39 PM   #13
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Please post a pic of the kids smiling, after you have heat!
Old 12-18-2013, 07:53 PM   #14
hotrodder
yEP, MOVE THE HOSE. THEN THEY WILL BE SMILEING LIKE THE PICTURE
hotrodder is offline   Reply With Quote
Old 12-19-2013, 10:03 AM   #15
R_W
R_W's Avatar
ROASTING HOT BABY!!!!
Old 12-19-2013, 10:11 AM   #16
1963c-10
1963c-10's Avatar
haha.....right on. Great pic and glad the heats back on.
Old 12-19-2013, 10:33 AM   #17
FetchMeAPepsi
FetchMeAPepsi's Avatar
Awesome mini-story with the kids! I subscribed just to see how it turned out. Stay toasty guys!
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 12-19-2013, 11:59 AM   #18
awbrown
A picture is worth a few words and about 50 degrees worth of heat .. New heater core 75 bucks , new hoses 20 bucks new thermostat 18 bucks new fan motor 50 bucks , heat in truck and smiling kids , priceless .... I rode to Springfeild Mass. once with a GM tech ,we about froze to death , I looked under the hood to find out his hoses were not routed correctly ,so we fixed it in the parking lot after finding a 7/8 wrench and a pipe nipple at the swap meet we were at ,it was a long trip home for the guy cause I rubbed it in ..
Old 12-19-2013, 09:03 PM   #19
earl84
Originally Posted by r_w View Post
roasting hot baby!!!!
best. Followup. Ever!
earl84 is offline   Reply With Quote
Old 12-19-2013, 09:19 PM   #20
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Glad you got yer heater fixed!!!! I'm lucky mine still works!!! All original 48 year old heater!!! And still warms the cab up! lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-19-2013, 09:35 PM   #21
Jeff La
Great thread
Jeff La is offline   Reply With Quote
Old 12-19-2013, 10:50 PM   #22
joedoh
joedoh's Avatar
I traded a bug for a galaxie once on the coldest night in a long time, -17 wind chills. My wife and daughter agreed to the trip across town in the bug, with its meted allowance of hot air heating (no coolant lines were backwards!), because the galaxie was advertised as having a 390 and a heater that would "melt yer face". After a lukewarm trip out west, we started for home and....
the heat did not work. our breath was freezing on the inside of the windshield, my daughter and the dog huddled in the back seat, and we froze all the way home. The next day I called the guy to chew him out and it turns out if you turned on the dealer installed AC, it would bypass the heater with nice fresh air from outside.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-19-2013, 10:57 PM   #23
jtrichard
T J you do know that now you have said something about how good and old your heater is it will soon start leaking
Old 12-19-2013, 11:01 PM   #24
NEWFISHER
NEWFISHER's Avatar
Truth
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 12-20-2013, 04:37 AM   #25
Rich 5150 69
Rich 5150 69's Avatar
GREAT ENDING...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
bleed, burp, heater, heater core
