Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-26-2013, 10:55 PM   #1
Gene
Gene's Avatar
HELP! 2012 Silverado Need a switched 12v fuse location for aftermarket stereo.
I have searched the internet and have came up with nada, can anyone tell me where on a 2012 Silverado I can access for an aftermarket stereo. The fuse panel by the e-brake doesn't have any 12v switched fuses. Are there any under the hood that are switched that I can use?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-27-2013, 09:40 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: HELP! 2012 Silverado Need a switched 12v fuse location for aftermarket stereo.
You should be able to get an adapter that plugs into the harness where the stock radio did.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 12-27-2013, 01:41 PM   #3
Gene
Gene's Avatar
Yes, I have that adapter harness. Only problem is it has an external 12v wire that says it needs to be connected to a 12 v ignition on supply. There is no such supply in the in cab.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 12-27-2013, 09:58 PM   #4
cableguy0
You need to get a better harness. There is also usually more involved than just putting in another radio. Aftermarket head units will blow the factory speakers because they run on different ohms. Its also possible you need te harness adapter that will allow the truck to actually start with the aftermarket radio.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-28-2013, 09:23 AM   #5
Special-Ed
Special-Ed's Avatar
Call metra and get a real aftermarket harness. If you have a premium factory radio you will need what they call a amplified harness. Call metra and tell them what truck and factory radio you have and they will make sure you have the proper harness
Head units are rated for an( 2-8 typical range) ohm load
Speakers are rated in ohms some are 2,some are 4,6 or 8 ohm loads.
Unless you are using some cheap imported junk of a head unit your factory speakers will be fine. Plan on replacing the factory speakers soon as well. They are cheap paper cones and will now be the weak link
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 12-28-2013, 02:47 PM   #6
Gene
Gene's Avatar
Figured it out, I do have a specialized harness. All I needed was a separate power source as the newer Chevrolet stereos do not have a dedicated 12v fuse. I found an ignition on fuse under the hood and now all is well. Speakers are fine, everything works great.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 02-28-2014, 03:26 AM   #7
54Caddy
GM Addicted
54Caddy's Avatar
but the way you have it hooked up it doesn't retain the 10 minute RAP mode, you need a pac module for correct install to retain all warning chimes and RAP mode. Retained Accessory Power- when you turn key off and leave doors closed radio stays on for 10 minutes or until you open drivers door.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-28-2014, 03:23 PM   #8
Special-Ed
Special-Ed's Avatar
Exactly why I told him to call metra. The right harness and module and it's a 20 minute job. And it will work like it's supposed to work. Not hacking it up.
Old 03-01-2014, 08:15 PM   #9
_Ogre
_Ogre's Avatar
with the 2012 head unit so integrated into your truck, there is no way i would remove it.
even with our sema cars we no longer remove the head unit; just update the speakers and amps
my 09 gmc has all the chimes, warings, turn indicators, bluetooth, steering controls and who knows what else built into the head unit.
shop air compressor timer
Old 03-02-2014, 01:58 PM   #10
nekkidhillbilly
what you done will work but your going to loose the chimes and rap. other option is a chime box harness there about 30 some bucks at walmart. you can change a 12 trucks radio btw and get a swc control adapters. my 04 has the harness splice cause idgaf about the chimes. the saturn had the chime box. scosche from walmart one. metra and pac ones cost double and arent as good really.
nekkidhillbilly is offline   Reply With Quote
Old 03-02-2014, 02:03 PM   #11
nekkidhillbilly
http://www.walmart.com/ip/Scosche-GM...arness/5691045
Old 03-18-2015, 09:48 PM   #12
Gene
Gene's Avatar
Nothing was hacked up, harness I have plugged in directly and it works fine.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
