Old 12-28-2013, 10:46 PM   #1
dmgibbs
Rear main seal
I am building a 1977 350 motor and cannot figure out witch way the 2 piece oil seal should go. I was told that if it is in backwards it will leak.
Does anyone have anyone have a photo of which side faces the crankshaft?
dmgibbs is offline   Reply With Quote
Old 12-28-2013, 11:36 PM   #2
79Betty
79Betty's Avatar
Re: Rear main seal
http://www.chevelles.com/forums/showthread.php?t=226648
No photo but good info. I personally didn't use silicone (and never will if i can) but try that out.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 12-29-2013, 01:00 AM   #3
Rnd
Re: Rear main seal
[IMG][/IMG]
I lifted this pic off of the net....
First rule of turning wrenches.....Pay attention to how it came apart..
Hope this helps..The lip faces in.
And be sure to use the "shoe horn" provided with the seal when installing the half that goes in the block.
Rnd is offline   Reply With Quote
Old 12-29-2013, 09:45 AM   #4
LONGHAIR
Re: Rear main seal
"Theoretically" that is good advice, but in actual practice, it only helps if it was done right the last time. Otherwise you are just repeating someone else's mistake.
There is no substitute for proper research.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-29-2013, 08:20 PM   #5
dmgibbs
Re: Rear main seal
That is exactly what I needed, Thanks for the reply.
Old 12-29-2013, 09:33 PM   #6
Rnd
Re: Rear main seal
[/QUOTE]
If you were referring to my pic you're welcome.....We all start somewhere and don't always have someone to ask.
I've mentored many up and comers in the "wrenching" bizz. Always helped 'em. But not without some form of advice to go along with the fix.
Wasn't trying to be a smart arzz.
"There's no substitute for good research".... Longhorn
I prefer "There's no substitute for skill and ability"
Randy
Old 12-30-2013, 11:27 AM   #7
Cherub
Cherub's Avatar
Re: Rear main seal
i prefer "there's no substitute for beer and luck"
Cherub is offline   Reply With Quote
