12-29-2013, 07:25 PM | #1 |
New crossmember or short tube headers?
I have a 77 lwb that i need to replace the exhaust.It has long tube headers now . Who sells a CHEAP! Transmission crossmember to clear a 3" exhaust? Went to the junk yard to find a double hump crossmember. No luck. Pics of your setup PLEASE!!
12-29-2013, 07:35 PM | #2 |
Re: New crossmember or short tube headers?
I just worked around with what I had, on my '77 l2swb. Duals, but still what you'd need to do to bring the passenger side over to the driver's side for single exhaust (if you went that way).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-29-2013, 08:05 PM | #3 |
Nice setup. Is that a kit? U have the same setup as me. I just hate how the drivers side has to be.
12-29-2013, 08:34 PM | #4 |
Not a kit - I put it together with a wack of mandrel U-s and some straight tube.
I debated long and hard about modifying the driver's side of the crossmember when a student of mine (I teach high school Mechanics) stripped a trans mount hole in the case and the crossmember had to come off to Heli-Coil it. I decided it would be easier to just suck it up and run the pipe over. I couldn't figure out any "quick and dirty" ways of putting a structurally-sound hump in the driver's side.
12-29-2013, 08:48 PM | #5 |
I had the same problem so I made a new one which gave me plenty of clearance.
IMG_5979 by Jesse Rieger, on Flickr IMG_5984 by Jesse Rieger, on Flickr |
12-29-2013, 08:58 PM | #6 |
That looks very reasonable. Was the e-brake cable an issue at all? Does it rattle against the exhaust?
12-29-2013, 09:51 PM | #7 |
At the body shop.
3/4-1 ton cross member. Small notch for the trans mount. Tucks 3"
" That didnt make it any newer " " Dont antique the equipment " |
12-30-2013, 02:26 AM | #8 |
12-30-2013, 03:39 PM | #9 | |
http://www.earlyclassic.com/catalog.aspx
01-11-2014, 10:57 AM | #10 |
are there any steps i need to take in removing the crossmember?
01-11-2014, 12:40 PM | #11 |
Support the trans tail shaft when you go to pull it out.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
