12-30-2013, 06:24 PM | #1 |
Truck runs fine for about an hour or 90 mins then dies
Anyone had this issue? My '83 K20 has an older 454 in it with an HEI. The truck will run fine for about an hour or so then sputter and die. When it starts to sputter, there are surges of power like the spark is flipping on and off. When it dies, it will start again after a while but won't run again without sputtering and dying until it cools off for several hours. I changed the ignition module and switched coils (using an old coil from another Chevy that runs fine). Going to put a new cap, rotor, and coil on just to be sure, but I'm thinking it might be the condenser? Will heat affect that and would it even be the cause? Could it just be a bad wire somewhere that is getting hot? When it runs it runs fine, smooth, and strong so I don't think it's a fuel issue, but maybe?
Thanks, I'm stumped! |
12-30-2013, 08:55 PM | #2 |
Re: Truck runs fine for about an hour or 90 mins then dies
There are a couple of things you need to check. When the truck dies, is it losing spark or fuel? To check if it's losing spark, pull a plug wire and put a good spark plug in it. Ground the base of the plug to the block and crank it over. If you see a bright blue spark jumping the gap on the plug, you have spark. Now, a quick check for fuel. When it dies, pull the breather off and pour a teaspoon or so of fuel down the throat of the carb, then crank it over. If it fires and tries to run, you probably have a fuel problem.
If we figure out which one you are losing, we can help you figure out why.
2005 2500 CCSB 4x4 Dmax/Alli, EFI-Live 2011 VW Golf TDI 6 speed manual 91 V3500 Crew cab Dually, 4X4, 454, 4L80E 87 V1500 Reg cab, 4X4, 350, 700R4 82 K1500 Reg cab, 4X4, 400, 700R4 |
12-30-2013, 11:43 PM | #3 |
Haven't tried the spark plug trick but it will start again after it dies. I can compression start it a few times as I'm rolling to a stop. If it only sits a few hours it will start, idle, and take off, but only a few 100 yards before dying again. If it is a fuel issue, what would cause it to die after running perfectly for over an hour, at speed and under load? (New filter, new gas tank sender).
12-31-2013, 12:01 AM | #4 |
You said you replaced the ignition module, did you replace it with a new one and did you coat the metal plate with the special heat transfer grease? I have seen those act similarly, they run fine until they heat up and then do all kinds of weird things.
12-31-2013, 12:14 AM | #5 |
Yep. New module and used the grease. The condenser lead was all twisted up and routed between the base plate of the distributor and the top of the engine so it was sitting right on top of the motor. I rerouted it so it went directly from the base plate to the cap. Was going to replace that (and condenser) next to make sure there isn't a broken or frayed wire that's getting to hot and choking out the signal from to many ohms due to heat.
12-31-2013, 12:26 AM | #6 |
Robert Olson Transport
years ago I had an f250 that had a similar issue with a condenser that was getting hot off the exhaust manifold and blowing a fusible link.. I would check the fuel pressure to rule it out but im betting that the condenser.. the other thing im suggesting you check is the whole distributor make sure there is no up and down play in the shaft
One other thought the coil you put in are you sure its good? Ive had several that came off the shelf in the suto parts store that were defective those were made by KEM since that incident years back I refuse to use anything other than AC Delco in the GMs
12-31-2013, 09:35 AM | #7 |
I kinda think its a fuel issue. 100 yards wouldn't heat anything up far enough to make it die (electrically), I wouldn't think. Also, to do the spark plug test, if you don't have a spare plug, just get a buddy to hold he end of the wire, but you have to do it early in the morning!! LOL Might not work any better, but will be more entertaining.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
12-31-2013, 11:11 AM | #8 |
May be a stupid question, but could you guys elaborate on what condenser you're talking about? Pics would be nice... what does it do?
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
12-31-2013, 01:43 PM | #9 |
If you are running out of fuel (no fuel squirting in the carb when you move the throttle by hand),
Try driving with the gas cap off. If the tank isn't venting, at some point the fuel pump cannot overcome the vacuum created in the tank by the exiting fuel, and the engine starves. After a number of hours, the tank eventually equalizes pressure through what little remains of its vent, and you can drive for a time before it starves again. Removing the gas cap allows the tank to take on air as fuel is drawn out. If nothing else, it's an easy test.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-31-2013, 10:14 PM | #10 |
Good point, here it is...you plug one end of the ignition control module into the condenser and pigtail plugs into the cap.
12-31-2013, 10:22 PM | #11 | |
12-31-2013, 10:26 PM | #12 |
Thanks for all the ideas so far, gonna hit it again after coming to tomorrow::
