Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-07-2014, 11:45 PM   #1
docflower
how to install stock radio
I have the stock AM radio, works great and in pristine condition.
Now how do I get it into the dash? I'm not sure of the least invasive method. No ac. Heater hoses are in the way.
Take out the hoses? Still stock, don't really want to unseat them. Can they be pushed out of the way.
Not really sure how to go about this.
Stock, 4spd manual, 72 c20.
Thanks!
docflower is offline   Reply With Quote
Old 01-08-2014, 12:54 AM   #2
docflower
Re: how to install stock radio
So a little push and it's in.
How do I set the presets?
Also, its a little loose. Is there a way to firm it in place toward the dash?
Old 01-08-2014, 12:40 PM   #3
earl84
IIRC, the presets are done by tuning to the radio station you want, then pulling the desired button out toward you, then pushing back in. Done.
earl84 is offline   Reply With Quote
Old 01-08-2014, 01:16 PM   #4
463
463's Avatar
Radio mounting — 1970–72 vehicles
1.Disconnect the negative battery cable and remove the flex hoses from the heater distributor duct under the dashboard.
2.Remove the heater control head by removing the attaching screws and pushing the unit back and down.
3.Remove the ash tray and the ash tray retainer.
4.Remove the electrical connections from the rear of the radio and also the front attaching screws and knobs.
5.Remove the mounting screw on the side of the radio chassis. Push the radio back and up before slipping it down and out of the instrument panel.
6.To install the radio, reverse the removal procedure.
Trueman
463 is offline   Reply With Quote
Old 01-08-2014, 04:33 PM   #5
docflower
Thank you for the responses.
Your post says there is a screw in the chassis of the radio. Where is this located?
I see the bracket extending from the speaker and have bolted those together, but still have some play. There must be another connection point or bracket that I an not aware of.
Old 01-08-2014, 05:46 PM   #6
463
463's Avatar
I think it is in the right side or the back of the radio that holds the radio to the dash.
If you run your hand around the radio you should feel the strap and bolt.
It helps to have a set of deep sockets to remove the holding nuts on the radio shafts (station & vol nobs )
Trueman
Old 01-08-2014, 11:57 PM   #7
docflower
What exactly do the holding nuts behind the knobs do? The name implies they should be holding sunbathing, but they don't seem to be doing anything.
Is the order on shaft: radio, nut, but, bezel, little oring washer thing, knob?
Thank you for your help.
Old 01-09-2014, 10:45 AM   #8
463
463's Avatar
Here is a pic on ebay http://www.ebay.com/itm/1969-1972-CH...-/121250316056
When the tune and vol knobs are pulled off there is ta chrome tone adjust knob then a nut then a tin holder. with the nuts removed the radio can then start to slide back into the dash.
when the radio out looking at the radio shaft there is still one nut on each radio shaft these nuts do not need to be removed.
Trueman
