01-09-2014, 11:19 AM | #1 |
What year horn button
Can anyone shed some light on what year this horn button is from?
Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
01-09-2014, 11:32 AM | #2 |
Cluster King
Re: What year horn button
That's a tough one Scott. May not be for a truck. It looks very similar to a 65 Impala. There is one on ebay but no description other than rat rod.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-09-2014, 11:39 AM | #3 |
Thanks Tbone, I bought it from a board member here thinking it was different.
Just curious what the original app might have been. Scott
01-09-2014, 11:57 AM | #4 |
That is 1966 Chevy truck, also same as 66 Nova. 65 Impala is taller with a plastic insert.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-09-2014, 12:17 PM | #5 |
Correction: the button is the same as 62-65 Nova for 66 Chevy truck . This is for the standard 1966 Chevy truck steering wheel.
01-09-2014, 12:37 PM | #6 |
66 truck 1 year only as far as i know. not sure about nova
01-09-2014, 12:49 PM | #7 |
thanks guys
07-30-2015, 01:49 AM | #8 |
I know this is an old thread. However, I wondering if anyone knew if this would be a direct replacement for the deluxe horn ring on my '66 or did they use different steering wheels?
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
07-30-2015, 03:52 PM | #9 |
You would use a standard steering wheel for this style cap.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-30-2015, 11:12 PM | #10 |
Thank you.
07-31-2015, 08:12 AM | #11 |
Actually there are two different Standard steering wheels for 1966 . One uses the Deluxe style wheel without the horn ring and the above style horn cap. The other is the same 60-66 except it came in three different colors, gray, white and fawn.
08-04-2015, 04:26 PM | #12 |
Heres the two versions of 1966 steering wheels using the same wheel for Deluxe cab and standard cab. ( 66 also used the same standard wheel as 1960-1965 but in fawn so there are 3 steering wheels for 1966 ) Pictures show the different mounting for the horn button VS the horn Ring.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 08-04-2015 at 04:31 PM. |
08-04-2015, 04:49 PM | #13 |
Thanks 60-66 for the pics and clarification. I wasn't aware that there were so many options in 66.
08-04-2015, 04:54 PM | #14 |
Registered Truck Offender
Wow,, 66 only!! I had no idea. Actually I tossed one in a tub I was taking to the swap meet and going to put a $10 price onthe entire tum (about worth that in scrap)
If anyone needs this 66 horn button,, send me a PM and I'll go dig through that tub. you can have it for the cost of a USPO small flat rate box!!! I surely don't need it!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-04-2015, 05:29 PM | #15 |
You learn something new everyday!! So what determined whether you got the 60-65 standard wheel with cap or the 66 deluxe wheel with cap on a 1966 standard cab?
08-04-2015, 08:30 PM | #16 |
THAT is the big question that needs some investigation !!
