Old 01-09-2014, 09:54 PM   #1
Lambchop76
5.3 swap
May be picking up a 5.3 and a 4l60e soon. What all will I need to swap it into my 87 r10? And what kind of headaches can I expect?
Lambchop76 is offline   Reply With Quote
Old 01-09-2014, 09:59 PM   #2
nekkidhillbilly
Re: 5.3 swap
wiring harness ecm and motor mounts are two must. im pretty sure you need aftermarket ac brackets and some fuel tank mods if you want dual tanks too. idk from there ppl will chime in though.
nekkidhillbilly is offline   Reply With Quote
Old 01-09-2014, 10:08 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: 5.3 swap
Lots of info here
http://67-72chevytrucks.com/vboard/s...d.php?t=350986
There is a Ls swap section under engines and drive trains on the board
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-09-2014, 10:19 PM   #4
nekkidhillbilly
Re: 5.3 swap
forgot to add you need maf from the newer truck and the gas pedal if its a drive by wire 5.3. idk what year you got.
Old 01-09-2014, 10:22 PM   #5
Lambchop76
Re: 5.3 swap
The deal comes with everything, ECM, ac, harness etc
Old 01-09-2014, 10:26 PM   #6
nekkidhillbilly
Re: 5.3 swap
what year is it out of? you will have to cut some odds and ends off the harness of stuff you dont need. idr what all. also what all do you want in the old truck. is it going to have ac and cruise? ls1tech is the best place to get all the info you need. idr all you need but its not a hard swap. ive not had a ls powered veh in 9 years so i have forgot so much about ins and outs and swaps.
Old 01-10-2014, 11:27 AM   #7
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Re: 5.3 swap
If you are getting Fuse block and all, check this guy out. I've done this on 3 different swaps and its worked out fantastic!
http://lt1swap.com/underhoodfuseblock.htm
He explains how to use the fuse block etc. Its very simple and looks clean when done.
If you have a 700R4 or 350TH your drive shaft should still fit ( splines will work ) you may want to do some measuring to get the correct placement of the engine and trans to keep from having the added expense of having a shaft made.
Read read read, there are so many ways to do this. But I can speak from experience, you will be glad you did it!
Good Luck!
bowtieguy79 is offline   Reply With Quote
Old 01-11-2014, 01:38 PM   #8
nekkidhillbilly
Re: 5.3 swap
if its a 700r4 its def the same shaft.
