'74 Rear Axle Application
The '74 K10 I bought last fall has had the rear axle swapped to an 8-lug, full-floating 14-bolt - FWIW, the front is a 6-lug Dana 44. The truck was originally a 454/auto with HD springs - would this have come with a 10 bolt from the factory, or a 12 bolt semi-float 6-lug? Also, as far as spring perches, shock mounts, etc. go, will a 10 or 12 bolt axle out of any 73-87 10 or 20 series truck bolt up to the K10 rear suspension?
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Re: '74 Rear Axle Application
Any ideas?
If it was a 74' K10, you would have had the factory 12 bolt semi-floater when it was new. They started using the 10-bolt rear later on (don't know when). I believe any year 12 bolt should fit, just make sure the gear ratios match the front axle.
Right on. Thanks!
Gentleman Jim Driver
The shock mount brackets are different between a 2wd and 4x4 axle. It's only a slight difference.
Also, the axle lengths are slightly different between the 2wd and 4x4. I've interchanged them in the past and it seemed to work ok.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Good to know. If I do find a possibly swap-able axle I'll compare/measure.
Ah! I see. Good to know. The mount holes for the shock studs on the frame have been moved down about 3 in. - maybe they figured out after the swap that the mounts are different, but compensated on the other end.
