Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-14-2014, 04:14 PM   #1
c60
C60 PTO help please
I am trying to find a pto for my Chevy c60. Right hand side, cable control, shaft output. It will run bidirectional pump for grain box. The transmission is a Clark 285v70.
What pto will work with this tranny? Is it the same as 285v or 282v? Salvage yards have not been much help. I need model numbers and or gear specs.
Any input would be much appreciated.
Thank you
c60 is offline   Reply With Quote
Old 01-14-2014, 05:51 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: C60 PTO help please
This was a
Chelsea PTO I used to have. Cost me $75.00 at a wrecking yard around here that specializes in trucks.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 01-14-2014, 07:30 PM   #3
mrolds88
Although I dont have an answer for you, you might want to post this over on the Heavy Haulers section. Lot of knowledgable guys on there.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-14-2014, 08:09 PM   #4
V30 mongo
You say you have to run a bidirectional pump. I think it will need a reversible pto unit. A Chelsea model 352 should do the job. It will need 5P-1025 input gear to be installed on a Clark 295V trans. Because it is a reversible type, a cable control will not work easily. A lever control should be used. I know you are trying to find something in the "junkyard", but, pto units, let alone a reversible type, will be a little hard to find just laying around.....
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers.
V30 mongo is offline   Reply With Quote
Old 01-14-2014, 08:24 PM   #5
c60
oops
Old 01-14-2014, 08:29 PM   #6
c60
Thanx for the input guys. By bidirectional I just mean that the pump can spin either way. It does not have to spin both ways. The tranny is a 285v70 not a 295v, so will a 5p-1025gear work on this tranny too?
Thank You for taking time to answer my questions.
Old 01-14-2014, 08:47 PM   #7
willett
Another Day, Another Dollar
willett's Avatar
Pto drives are fairly universal from my experience. *unless its an NP203 or some reason :| There are 2 sizes that I encounter on a regular basis. The small 6 bolt that yours appears to be, and the big 6 bolt that is on heavier duty trucks. This being said there is potential for different gear cuts etc.. But I think you would be good with a pto from just about anything with that 6 bolt pattern. I was pricing out Chelsea units a while back for an Np205 which I think is the same as you need and it wa only about $300 new.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-14-2014, 08:58 PM   #8
V30 mongo
Did a typo, the 5p-1025 gear in the Chelsea 352 is for the SM420 and the Clark 285V. If you do not need a reversible pto unit ,your search should be a little easer. The output direction of most pto units is opposite engine. Check your pump to see what is required. Also you should find out how much power you need. A small pto unit will only be able to transmit no more that 8 to 10 HP and they will only have sleeve bearings that can't be run for a long time. Also most pto units, even the larger ones, will be able to transmit no more that about 35 HP. If you need more power a split shaft unit will be required.....
