01-28-2014, 05:05 PM | #1 |
Hazard Switch
Hey Guys,
New to the forum, but have been playing with my C10's for a while. My question to the groups is. A 1971 C10, which type of hazard switch should it have. The Red style or the black mushroom style. Thank you for the help in advance Double C |
01-28-2014, 06:50 PM | #2 |
Re: Hazard Switch
My 71 C/30 has a red one
The interior is original (except later model Chevy steering wheel, CB and Pioneer Supertuner). Even though I've got a C/30 I figure a C/10 would be the same. Don't know if there was a midyear change but my truck was built in April 1971 if it matters.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72 1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code" 1970 Mercury Cougar "Eliminator" 351C-4V C6 1972 Ford Ranchero GT 351C-2V C6 1974 Honda XL-350 Member of the "6 C's and a D" 1-Ton Fun Club! |
01-28-2014, 07:01 PM | #3 |
Re: Hazard Switch
71 Dually,
Thanks for the photo and the information. I found a 4 speed tilt column that I'm going to install, and I found a company that sells the Red switch style turn-signal assy., just trying to make it look correct. |
01-28-2014, 09:03 PM | #4 |
Re: Hazard Switch
Where did you find it? I need to replace my broken one.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-29-2014, 01:10 PM | #5 | |
Re: Hazard Switch
http://67-72chevytrucks.com/vboard/s....php?p=4250625 Last edited by FirstOwner69; 01-29-2014 at 01:15 PM. |
01-29-2014, 01:59 PM | #6 |
Re: Hazard Switch
The truck tilts do not use the red flasher style. They use the black style or there is a chrome flasher knob that looks great!
01-29-2014, 03:57 PM | #7 |
Re: Hazard Switch
Here's a picture of the chrome knob 70shortfleet mentioned installed.
01-29-2014, 11:44 AM | #8 |
Re: Hazard Switch
NC_John,
A company in CA called M&H electric has replacement harnesses and components |
01-29-2014, 10:19 PM | #9 |
Re: Hazard Switch
Thank you sir- I helped install an M&H harness last weekend.
01-30-2014, 12:26 AM | #10 |
Re: Hazard Switch
Sorry to too high jack the thread but this might help out some other poeple. My red hazard nob is broken and i would like to replace it. Is there a way to replace just the knob, or do you have to replace the whole switch. The turn signal swtich with red knob was 42.00 at M&H.
01-30-2014, 06:25 AM | #11 | |
Re: Hazard Switch
I went through the M&H site but didn't see the hazard switch. What's the PN? I haven't been able to find a repop of the original red button by itself, just the round black ones....
12-03-2020, 12:53 AM | #12 |
Re: Hazard Switch
Will that chroma known work with a non tilt column instead of the red one?
12-03-2020, 10:49 AM | #13 |
Re: Hazard Switch
12-03-2020, 11:25 AM | #14 |
Re: Hazard Switch
That is the tilt column turn signal harness? Will that still work with the non-tilt? Thank you!
