Old 02-03-2014, 12:06 AM   #1
krazy_texan
krazy_texan's Avatar
Rear passenger door latch
Ok so 2 times now I have disassembled my right rear passenger door to fix the latch and both times I had it working until I reassembled the door put the panel on it then it quit I laugh about it but at the same time it's frustrating. I tried getting the latch out so I could get either repair or replace it. My biggest issue was that I could not get the clip off that held the rod from the outside door handle so do you guys got any pointers
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-03-2014, 12:43 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Rear passenger door latch
my 78 used a metal clip it has a little catch you have to lift up,the clip is tapered to a point over the clip
my later ones 87,88 use a plastic clip,you have to turn it away/off from the rod,(feel a slight pop)pull out the rod and the clip comes out
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
