Old 02-12-2014, 01:39 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question Mounting Accuair Leveler sensors
I've already done this with my suburban about 4 years ago when these first came out. It was kinda of a pain the way I did it (welding involved). I'm getting ready to do this on my son's 68 and was wondering what new and creative ways everyone has been mounting these now. Thanks in advance!
Hart_Rod is offline   Reply With Quote
Old 02-12-2014, 03:05 PM   #2
fastbagged68
fastbagged68's Avatar
Re: Mounting Accuair Leveler sensors
You can get collars from McMastercar and drill and tap them. Mount them to your pb trailing arm. Then for the frame you can weld or make a c channel bracket to bolt the sensor to. If you do a c channel you can slide it around to figure out the travel.
I have also installed the collars on the front shocks or tap the control arm. Mount the sensor on the pb upper airbag mount. Backside of control arm.
fastbagged68 is offline   Reply With Quote
Old 02-12-2014, 03:48 PM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Interested as well, I know there were some previous posts on the subject, and from those I grabbed a few photos.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-12-2014, 04:08 PM   #4
Mieser3
Mieser3's Avatar
I made some spacers out of thick aluminum tubing to mount my sensors to the frame for the rear and to the front crossmember for the front. I also used the aluminum collars from McMaster-Carr. If you need part numbers on the collars let me know...I think I've still got them in my inbox somewhere.
Jay
1956 Chevy 210 Sedan
1970 Camaro Z-28/RS
1970 Chevelle SS 396 (numbers matching L34 car)
1971 Chevy SWB Fleetside with 1967 front clip - in progress
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156
Mieser3 is offline   Reply With Quote
Old 02-13-2014, 07:04 AM   #5
mac808
mac808's Avatar
Hey Rob,
I had a couple pics posted on my PB write up thread but here is how I have mine mounted up in front:
The rear is similar to those already posted, mounting at some point, inside or outside the trailing arm.
I believe one of the ways that Nate and PB recommend or have set up most of their installs is like pic #2, with a adapter plate mounted on the inside of the frame rail for the e-level sensor and the rod attaching to a fixed point on the trailing arm. A collar shaft is probably the best option if you have tubular arms.
mac808 is offline   Reply With Quote
Old 02-16-2014, 11:16 AM   #6
grs
Hey man i could use those part numbers been looking all over for those collars lol i figured mcmaster car would have them good thing is I'm 40 mins south of them so i get them same day
grs is offline   Reply With Quote
Old 02-16-2014, 11:20 AM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks all! Part numbers would be great!
Old 02-16-2014, 01:09 PM   #8
STPrider
STPrider's Avatar
If you wanna get something happening cheap/fast, I used exhaust clamps and they worked really well!
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 02-17-2014, 03:14 PM   #9
Mieser3
Mieser3's Avatar
Here's the part numbers on the collars. Hope this helps.
www.mcmaster.com
Just tap them and thread in the ball mount and they are good to go...the fronts you have to shorten the ball stud a little so its flush on the inside but the rear is perfect. These are the part numbers if you have the Porterbuilt control arms and trailing arms. These are aluminum so you can polish them too.
Part# 6436K74 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 1-1/4" Bore, 2-1/16" Od, 1/2" Width
Part # 6436K76 2 Each Two-piece Clamp-on Shaft Collar, Aluminum, 2" Bore, 3"outside Diameter, 11/16"width
Jay
1970 Camaro Z-28/RS
Old 02-17-2014, 03:55 PM   #10
slowcpe
slowcpe's Avatar
Interested as well. Haven't ordered mine yet, but getting close.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-17-2014, 09:25 PM   #11
jtp67-72
jtp67-72's Avatar
And here is a pic of both of them..not cheap but real effective...jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 02-17-2014, 10:37 PM   #12
Hart_Rod
Hart_Rod's Avatar
www.mcmaster.com
Just ordered mine, thanks!
Old 02-27-2014, 07:10 PM   #13
fastpace
Using this thread as a guide the shop just got done installing the e-level sensors on mine. I really liked the idea of using the clamps to mount to the trailing arms and LCAs. I also didn't really like the crappy plastic heims that came one the original rods, so I ordered some steel replacements. Here's the parts and prices I ordered from McMaster:
(2) Collar clamp for trailing arm - McMaster Carr - $36.82 - 6436K76, 2-piece Clamp-on shaft collar for 2" dia. aluminum
(2) Collar clamp for LCA - McMaster Carr - $20.14 - 6436K74, 2-piece Clamp-on shaft collar for 1-1/4" dia. Aluminum
(8) 10-32 heim for e-level rods - McMaster Carr - $26.56 - Steel ball join rod end, 10-32 RH female shank, 3/16" ball ID
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 05-25-2020, 01:20 AM   #14
Chvy2NV
I picked up some brackets from choppin block.. about $12.00 a piece.. they have them in all sizes. they also make a billet one thats a couple more bucks.. Ill be mocking up my sensors soon.. ill try to get some pics of what I do.
Chvy2NV is offline   Reply With Quote
