02-13-2014, 07:10 PM | #1 |
Drive Shaft install question
I tried installing the drive shaft this weekend and I was unsuccessful.
This is a 72 K5 4x4 and it seems like its a couple inches to long? Is there something I am doing wrong? The motor and trans are installed in truck now. Do I need to loosen the motor mounts and move the motor/trans forward a little? This drive shaft did come out of this truck, I wasn't the one to take it out tho. thanks |
02-13-2014, 07:25 PM | #2 |
Re: Drive Shaft install question
If the driveshaft is too long when the truck is on the ground, you have a problem. The driveshaft needs to be shortened. If the truck is on a lift, or the rear end is allowed to fully sag, the rear end will rotate towards the transfer case a bit and effectively shorten the distance between the axle yoke and t-case output yoke. This is still a problem because if you get that driveshaft in and you ever end up with the rear in full sag, the driveshaft will be in compression and pushing on the transfer case and axle yokes. I have seen transfer cases damaged in this way.
Did you by any chance do an axle swap? A larger axle will have a longer pinion snout and will require a shorter driveshaft. |
02-13-2014, 08:53 PM | #3 |
Could the tail shaft of the tranny be different?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. Members Met: Aldtime, DeadheadNM |
02-14-2014, 12:25 AM | #4 |
Did you change the set up? Tranny and t case or maybe axles?
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
02-14-2014, 09:00 AM | #5 |
Rottenwood Garage Member
As long as all of the running gear is the same and mounted in the same location it should fit. Are you having trouble getting it up in the transfer case? Post a picture of how far it is going in.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
02-16-2014, 03:54 PM | #6 |
Here are the pics!
02-16-2014, 04:07 PM | #7 |
Is it equipped with a carrier bearing?
02-16-2014, 05:46 PM | #8 |
02-16-2014, 06:32 PM | #9 |
Is it a 2 piece drive shaft? The carrier bearing is the mounted point between the 2 parts of the drive shaft.
02-16-2014, 08:14 PM | #10 |
It's a 1 piece
02-16-2014, 11:13 PM | #11 |
If you ran out of slip in your slip-yoke you might have too much grease at the end of the splines. None of the pictures shows how much you have left on the splines. I'd pull the slip yoke off and remove the excessive grease. Be sure to line it up right going back together and grease it when your done. Just a suggestion without having seen it.
02-17-2014, 01:29 PM | #12 |
Can you tell me if this is the slip yoke and do I need to loosen that bolt to get it out?
02-17-2014, 01:33 PM | #13 |
02-17-2014, 01:53 PM | #14 |
Here's a picture of some typical drive shafts at
http://www.dennysdriveshaft.com/c4_4x4_driveshafts.html . The slip-yokes are the shiny bits on the left of the shafts. |
02-17-2014, 07:20 PM | #15 |
It's not far off at all. Looks to me like Jeffro is right. The slip yoke only needs to go about 1/2" in. Since that's the fixed end, you'll see where the other end is splined so the driveshaft can shorten and lengthen depending on terrain, driving conditions, etc. you wouldn't be able to do anything with a fixed driveshaft, short of driving straight down a level road.
02-17-2014, 09:10 PM | #16 |
Here is the drive shaft and it opens up like a shock.
The pic with the arrow: Is this side the slip yoke? Do I have the right drive shaft? PO gave me 2 drive shafts. |
02-17-2014, 09:21 PM | #17 | |
Oh, the bottom picture is a front driveshaft. |
02-18-2014, 12:21 PM | #18 |
I bought it this way, Is it possible that the motor is mounted to far back?
It sure seems like it to me, But I have no idea. |
02-18-2014, 04:47 PM | #19 | |
Those rear springs look fairly new. Is it possible that the rear axle has been shifted forward a little? Is the locator spring centered in the spring? Could the springs be backwards? I'd recommend that you join a 4 wheel drive club or something and befriend some people there locally with some more extensive general mechanical knowledge. |
02-18-2014, 06:30 PM | #20 |
I had to take the cap off of the rotor for it to fit.
02-18-2014, 07:45 PM | #21 |
Can you post a picture of your rear spring setup?
02-19-2014, 02:30 PM | #22 |
Here are the pics.
02-19-2014, 03:07 PM | #23 |
You have round U Bolts and you should have square "U" bolts on the rear axle.
It looks like the PO tried to compensate for the mismatch with some type of insert on top of the leaf spring pack. |
02-19-2014, 06:38 PM | #24 |
Something aint right there. Is it a lifted truck? If you tried to put the shaft in like it is it won't fit. You have to push the end in first so the end that moves is in as far as it goes and then pull it out as needed to fit the yoke. My 4 wheel drive has round u bolts but sideways and hold the axle tube itself and clamps from the top of the spring. Axle looks correct. Is it centered in the wheelwell?
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
02-19-2014, 07:01 PM | #25 |
Any chance the 52" rear springs were swapped out for longer ones? That would likely offset the rear axle, but would be noticeable if the body is mounted to the frame. FYI your rear leaf spring u bolts should be the square type when mounted from the top to bottom like that. Those ones would mount around the axle tube like chulisohombre said. I wouldn't take any chances when it comes to the drive train. I don't think the u bolts Would suck down as tight in that position. The piece sitting on top of the spring pack, and the saddle around the axle tube is correct with square bolts. If you keep the round u bolts you will need a plate that goes on top of the spring plate and run the u bolts up. If you go that route i may have a set of spring plates. Let me know.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 Last edited by Jdubs71; 02-19-2014 at 07:36 PM. Reason: Added info |
