Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-14-2014, 06:54 PM   #1
Flat 67
Junior Member
Flat 67's Avatar
1971 C50 Swap Project
This is what I started with. A 71 C50, with a 350, 4speed and 2 speed rear end.
Flat 67 is offline   Reply With Quote
Old 02-14-2014, 07:06 PM   #2
Flat 67
Junior Member
Flat 67's Avatar
Re: 1971 C50 Swap Project
After owning it a while I wanted to makes some improvements and take care of some problems.
Things to fix/improve:
Leaking brake cylinders
Leaking master cylinder
Widowmaker split rims
20 tires with tubes
Smelly gas tank behind seat
Rearend with very low gears
Bad clutch
No power steering
Old 02-14-2014, 07:25 PM   #3
Flat 67
Junior Member
Flat 67's Avatar
Then I came across this donor truck for a fair price. A 1988 GMC 7000
With the following:
8.2 Turbo Detroit Diesel (not a desirable motor, oh well)
10 speed Eaton Fuller Transmission
4.88 rear end
22.5 steel wheels
Tubeless tires
Air brakes
Power steering
2 50 gal fuel tanks
So.....The swap began!!!
Old 02-14-2014, 09:07 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Does the '88 7000 actually have a Fuller 10-Speed Road Ranger Trans? If it does, I've never seen one in a Medium Duty truck of that type.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 02-14-2014, 09:51 PM   #5
Flat 67
Junior Member
Flat 67's Avatar
Bill,
Yes it does, when I first saw it didn't think it could be so.
Old 02-14-2014, 10:19 PM   #6
flashed
My brother n law has a truck just like the one you are starting with that he hauls hay with on the farm ,same color even .Im in for this one .
flashed is offline   Reply With Quote
Old 02-14-2014, 10:20 PM   #7
C10 - C90 Bill
Pretty interesting. Cool Truck really. Air Brakes and all.
GMC 9500 Fan
Detroit Diesel Fan
Old 02-14-2014, 10:43 PM   #8
Flat 67
Junior Member
Flat 67's Avatar
The teardown begins.........
Old 02-15-2014, 12:12 AM   #9
flashed
This is going to be a cool truck.
Old 02-15-2014, 04:27 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
what truck? I thought this was about a girl....
Rich
1972 K5 Blazer CST Click HERE
Old 02-15-2014, 09:27 AM   #11
flashed
She can ride along too.
Old 02-20-2014, 06:02 PM   #12
Flat 67
Junior Member
Flat 67's Avatar
Pics of it coming together.
Old 02-20-2014, 06:04 PM   #13
Flat 67
Junior Member
Flat 67's Avatar
Front wheels stick out until I make the 8 inch cut to the front axle.
Flat67
Old 02-20-2014, 07:58 PM   #14
C10 - C90 Bill
Before you cut the Front Axle, you may want to consider going with the Wide Fenders, found on some C-60's with the Heavy Front Axle. They should interchange with no problem. You would also need the Wider Running Boards as well.
I'm really not a fan of converstions, but that Front Axle looks pretty cool under there. I also like the idea of a 10-Speed RR Trans in C-50.
GMC 9500 Fan
Detroit Diesel Fan
Old 02-20-2014, 11:10 PM   #15
junkmandan3
junkmandan3's Avatar
Retro look with the later model running gear with great components, possibly except for the engine............... But they're stingy on fuel. The transmission is worth as much as the engine, maybe more !
Did you have to cut the firewall to clear the turbo and exhaust pipe /
junkmandan3 is offline   Reply With Quote
Old 02-20-2014, 11:32 PM   #16
mrolds88
Couldn't you use a C70 type fender? Would it be bolt on??
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-20-2014, 11:50 PM   #17
C10 - C90 Bill
They are the ones I am referring to. The hardest part would be to find a nice set.
GMC 9500 Fan
Detroit Diesel Fan
Old 02-20-2014, 11:57 PM   #18
C10 - C90 Bill
Here is a good example of the Fenders.
Last set of pictures, post #356:
http://67-72chevytrucks.com/vboard/s...306565&page=15
GMC 9500 Fan
Detroit Diesel Fan
Old 02-21-2014, 12:03 AM   #19
Flat 67
Junior Member
Flat 67's Avatar
Bill, like you said, the wide fenders are very rare and they would probably be all rusted. Those sample pics are a great examples though. Also, I like my original paint too much and I don't want to alter that.
Old 02-21-2014, 12:10 AM   #20
Flat 67
Junior Member
Flat 67's Avatar
Mr. Junk
No cuts were made to the fire wall. It was a snug fit though.
Flat67
Old 02-21-2014, 12:20 AM   #21
Flat 67
Junior Member
Flat 67's Avatar
More pics......I got it running.
Old 02-21-2014, 06:04 PM   #22
Flat 67
Junior Member
Flat 67's Avatar
Motor is snug, but fits in there.
Old 02-21-2014, 06:09 PM   #23
Flat 67
Junior Member
Flat 67's Avatar
Boy, it takes a few air lines to run these air brakes. I had to number them as to not get them confused. They came out ok, they work just great.
Old 02-21-2014, 09:12 PM   #24
flashed
That was quick ,I like it .
Old 02-21-2014, 11:46 PM   #25
Peanutbutter
That 88 GMC 7000 looks just like my 79 but mine had 453T jake brake and 5 and 2. I really miss that truck.
Peanutbutter is offline   Reply With Quote
