Old 03-06-2014, 04:03 PM   #1
Brave71
Tilt column problems
The tilt column I got with the truck I bought was not installed yet.It looks like it's rebuilt and very good shape.I notice it does not have a tang that sticks up to make the back up switch work? There is a slot there but no tang, the blow up diagram in my service manual doesn't show a back up switch on the column.any one have ideas? Thanks so much with your help with my problems,this web site is great!
Brave71 is offline   Reply With Quote
Old 03-06-2014, 06:35 PM   #2
john
member #16
john's Avatar
Re: Tilt column problems
If you have a converted van column, they use a different switch than the truck they fit into a slot rather than over a tang.
john is offline   Reply With Quote
Old 03-06-2014, 08:03 PM   #3
uncle
How long is shaft coming out bottom of column. That's a give away also.
uncle is offline   Reply With Quote
Old 03-06-2014, 08:03 PM   #4
Brave71
Thanks .. Any idea where I could get a back up switch for van column?
Old 03-06-2014, 08:18 PM   #5
JimKshortstep4x4
Most van columns have the switch in the wrong location. The switch needs to be in the truck switch location which is about 8" from the lower end of the
column.
You may want to check the location of the switch on your tilt.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-06-2014, 08:38 PM   #6
71swb4x4
71swb4x4's Avatar
Post some pictures of your column on here, we can tell you exactly what you have.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-07-2014, 12:46 AM   #7
michael bustamante
michael bustamante's Avatar
Scribed
1967custom
michael bustamante is offline   Reply With Quote
