03-07-2014, 02:34 AM | #1 |
Airbag diagram
Does anyone have a diagram how to set up an air management system? Switches, bags, compressor,etc.
03-07-2014, 07:32 AM | #2 |
Re: Airbag diagram
Well issue is there are lot of different systems out there. The basics are the same till you get to the valves. and the control for them. I have a E-level system for my truck that is plug and play on the wiring for the valve block with just the 4 lines from the bags plugged in to it. Then I also have a system where I have 8 valves with 4 going to the bags and 4 dump valves all wired to 4 rocker switches to control the air in each bag. I have my tank plumbed with the compressor hooked right to to it with a switch to turn it off when needed and the main power on a relay that is run by a pressure switch on the tank. Line off the tank runs to the valve block. A good source for information is places like Ride Tech and Airbagit.com both have tech sections that go over the types of systems well.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-07-2014, 07:41 AM | #3 | |
Re: Airbag diagram
03-07-2014, 08:42 AM | #4 |
67-72 parts collector,…
Re: Airbag diagram
here you go,...
03-07-2014, 08:55 AM | #5 |
Re: Airbag diagram
Thank you lolife. That's what I was looking for.
Do you have a wording diagram for this setup as well? |
03-07-2014, 08:59 AM | #6 | |
Re: Airbag diagram
I just stole it off of the internet. Use Google to search. There is tons of air ride info out there. Also check out Accuair's website. They seem to be the current leader in air ride air management. http://www.accuair.com/classic
03-07-2014, 03:51 PM | #7 |
Re: Airbag diagram
I assume you meant wiring. The same website has wiring diagrams as well. Can't post links here because they blocked but it's easy to find.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-07-2014, 06:30 PM | #8 |
Re: Airbag diagram
03-14-2014, 10:42 PM | #9 |
Re: Airbag diagram
Here's my valve setup, fill from the top (from the tank) and dump from the bottom, middle line runs off to the bag. HTH
another angle, failing a leak test with soapy water:
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo '81 C-10 SWB Parts Truck IRC - http://webchat.snoonet.org/#baggedtrucks |
03-14-2014, 10:50 PM | #10 |
Re: Airbag diagram
What controller are you using?
03-14-2014, 10:51 PM | #11 |
Re: Airbag diagram
none, just momentary switches
