Old 03-07-2014, 09:28 PM   #1
-T-
-T-'s Avatar
I have hit a road block with my 5.3 swap
I have done a dozen of these swaps and never had this problem or many problems to speak of. This one is in a 70 C10 short bed. The motor has been in and running for over a month. I have driven it around the parking lot at my shop and moved it around the shop a dozen or more times while continuing the build. Last week got the truck out drove around a little and did a few donuts then pulled it back in the shop. Everything was fine an this point. Few days later, start the truck up to move it and its running rough, like a misfire. Checked fuel pressure at this point and everything was at 58 like normal. This week, go to fire it up and nothing, i mean nothing. It will prime the fuel pump, hold pressure and just spin over. Today I hooked it up to the lap top and no DTC's are recorded. Pulled spark plugs and they are firing, pulled the fuel rails, and they are pulsing and have a good fan of spray. It is wired using the stock fuse block like I have done all my others. I have had one die on me before that ended up being the fuse block but it wouldn't do anything, not even prime the fuel pump. Any thoughts would be appreciated.
-T- is offline   Reply With Quote
Old 03-07-2014, 09:46 PM   #2
clinebarger
Re: I have hit a road block with my 5.3 swap
Did you pull the plugs? They are surely fouled by now. Sounds like what I call "Lot Rot". Starting it & not driving it over & over will foul the plugs & most likely has a good amount of fuel the oil.
clinebarger is offline   Reply With Quote
Old 03-07-2014, 09:49 PM   #3
-T-
-T-'s Avatar
I have not pulled the plugs, I assumed a running motor was good to go. Have you encountered this before where it was running then just did nothing? Will a simple plug change fix it? Thanks again for the reply
Old 03-07-2014, 10:16 PM   #4
clinebarger
All The Time when I worked a car lots, They will run, Then run like crap, Then Not run.....You can do a "Clear Flood" procedure on it, Depress the accelerator all the way while cranking. This is hard on the engine tough.
Old 03-08-2014, 08:05 AM   #5
-T-
-T-'s Avatar
I have held the pedal to the floor a few times, I'll just change the plugs and go from there. Anyone else have any thoughts?
Old 03-08-2014, 08:31 AM   #6
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Of course as you know, three things required to run- spark at the right time, fuel, and compression. It cant be compression, so Id pull the plugs and see if they are wet. If they are, its either not firing or at the wrong time. If the plugs are dry, its a fuel issue. HTH
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-08-2014, 08:43 AM   #7
dman1982
dman1982's Avatar
did you check the air intake? is it tight? no holes or loose sensors? what your describing sure sounds like this
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-08-2014, 08:49 AM   #8
-T-
-T-'s Avatar
the air intake was on and tight at the time of the decline. Nothing on the motor side of things had been changed between running great and not running. It ran to good to start with to be a problem with a loose sensor or something of that effect. Ill double check of course but it seems unlikely. Thanks again everyone for the ideas. They are all things to double check.
One of our thoughts was that it may have jumped a tooth on the timing chain, but thinking about how that would act, it ran fine after the donuts and when i pulled back into the shop. If it had jumped time the affects would have been immediate i would think.
Old 03-08-2014, 08:59 AM   #9
dman1982
dman1982's Avatar
ya i know it sounds kinda stupid, but just a couple weeks ago my step daughters lexus started running like crap....the air intake tube was bad...and a few years ago i had a similar issue with my danger ranger..the intake tube was just off the throttle body (you couldn't hardly see it) and was driving me crazy...so when my fuel injected vehicles start acting like crap that the first thing i check
and if it did jump a tooth you'd think it would be immediate
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-08-2014, 12:06 PM   #10
ls1nova71
ls1nova71's Avatar
^^^^^ This is probably your problem. I had this happen back when I was building my street rod. Started fine at first but one day it started running worse and worse. , plugs were wet. I took a propane torch to the ends of them to get them to work again as a test. Finally put new plugs in it and all was well. 70k miles later its still running like a top.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-08-2014, 02:56 PM   #11
-T-
-T-'s Avatar
Thanks. That's my next plan of attack on Monday. I'll report back. Thanks for the responses
Old 03-08-2014, 07:25 PM   #12
Special-Ed
Special-Ed's Avatar
It could be ethenol related as well. Modern fuel sucks. Literally. It pulls water out of the air and without some kind if stabilizer become bad within a couple months.
Again. Related to lot rot.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 03-08-2014, 11:46 PM   #13
-T-
-T-'s Avatar
Thanks for the advice guys, I couldn't wait till monday so I got a set of plugs from my brother tonight and headed to the shop. We did a compression test on all 8 cylinders, they all passed, and replaced the plugs. Fired right up. I was pleasantly surprised that it was something that simple.
Old 03-09-2014, 09:16 AM   #14
dman1982
dman1982's Avatar
thats awesome...like the love hate relationship...ya love that its such a easy fix but hate it at the same time
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-09-2014, 11:58 AM   #15
Super73
Super73's Avatar
Do you have a scanner like hptuners or efilive that will show you sensor info in real time?
I once had a similar issue and saw on the scanner my TPS went haywire.had fuel, had spark but did not fire.
Double check cam sensor as well.. they will run with out it, but it can make it real hard to start with out it.
Also, pull a valve cover and confirm you did not loose a timing chain.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-09-2014, 03:23 PM   #16
-T-
-T-'s Avatar
as stated above, 8 spark plugs did the trick.
Old 03-11-2014, 02:20 PM   #17
ERASER5
ERASER5's Avatar
I say it was because you fed the truck doughnuts. I run lousy after doughnuts too.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-11-2014, 09:21 PM   #18
-T-
-T-'s Avatar
Touché ! I like it
