03-15-2014, 01:14 PM | #1 |
Ridepro E3 Dilema
So I purchased a Ride tech Ridepro E3 mangement system. I'm running two three gallon tanks mounted infront of the rear wheels on PB mounts.
The E3 only has provisions for on pressure switch to run one tank. I was wondering if anyone else has run into this issue and how to go about resolving it. I don't think splicing the wire and running two pressure switch is an option. I've sent Ridetech a message. But, I'd figure I try here too.
///Relaxed Atmosphere |
03-15-2014, 01:22 PM | #2 |
67-72 parts collector,…
Re: Ridepro E3 Dilema
As long as you connect your tanks together,... one pressure switch is enough.
The switch sees pressure. It doesn't care where it comes from.
03-15-2014, 01:45 PM | #3 |
After a little thinking, I think that's might be feasible.
03-15-2014, 01:30 PM | #4 |
Thats kinda the issue. I'd have to connect from one tank on one side of the truck to the other tank on the other side of the truck. I'm not sure if that's the ideal set up? I wish there was a way to not run air line connecting the two and I could run two pressure switches.
I was wondering if there is a way to bypass that portion of the E3 (or not even use the tank display feature) and connect the compressors using the just a switch on each tank
03-15-2014, 01:46 PM | #5 |
Never Ending Projects
Why would you not want to connect the two tanks? You want the system to share the full capacity of both tanks evenly. You can have one 6 gallon tank or two 3 gallon tanks or even six 1 gallon tanks. You want them all hooked together. Each one of those systems would be equal to 6 gallons. One pressure switch is all that is needed for any of those setups. All tanks would be at an equal pressure, together.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
03-15-2014, 02:23 PM | #6 |
You don't have to run the larger 3/8" line. A 1/4" line would work just as well to link the tanks together.
03-15-2014, 02:26 PM | #7 |
In thinking it over and from what has been suggested I think I will run S.S. braided line and -6 A.N. fitting from one side to the other.
03-15-2014, 03:31 PM | #8 |
How about a pic of the frame with the PB mounts, got the same setup just haven't decided where to mount
My 1970 C10 Build "Project Teacher" |
