Old 03-15-2014, 03:57 PM   #1
swissarmychainsaw
Where to find: SEAT BELT SHOULDER BOLT
I'm trying to add shoulder belts to my 73 Suburban (front and rear).
I found a set of the Shoulder (pivot) bolts that go into the B-Pillar, but for the life of me I can't find them new anywhere.
I'm hesitant to just buy a bolt from the hardware store since these are kind of specialty and the hardened versions are not quite the same from the local ACE.
Juliano's sells this bolt but it's a 3/16" Fine thread, and mine is more like
a 1/2 Coarse.
Where do I find this?
Thanks!
swissarmychainsaw is offline   Reply With Quote
Old 03-15-2014, 08:19 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Where to find: SEAT BELT SHOULDER BOLT
You found a used set? Why not run them?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-15-2014, 08:45 PM   #3
swissarmychainsaw
I found 2 but need two more for the other side!
Trying to get 4 proper shoulder belts in the beast!
Old 03-15-2014, 09:40 PM   #4
68Timber
68Timber's Avatar
There are so many trucks being parted out the 73-87 classified section, you should be able to get two more cheap if your local junk yards are bare.
John
74 Honda Z50 build
