Old 03-17-2014, 11:39 AM   #1
Poulsbo
Crank Question: Do I need to regrind?
Another rookie question...this time about a small scratch that developed after initial preassembly.
Here's the story.
I checked all main and rod clearances using micrometers and a bore gauge. Everything checked out.
I then installed the cam, crank and timing chain kit (using Napa engine assembly lube just like final assembly.)
I then test fitted my heads, and went to work on getting my valve train geometry right. (Thanks again for the help of this forum!)
I got everything where I felt comfortable with the set up...then I disassembled the whole thing.
The only trouble is that when I pulled off the rod caps on the #1/2 journal there was a new scratch about 1.5" long, right down the middle, between the rod bearings. (See attached picture for detail)
Question: Do I need to have my crank reground/polished? Or is this a non-issue?
Thanks again for any help.
Poulsbo
Poulsbo is offline   Reply With Quote
Old 03-17-2014, 11:57 AM   #2
68post
Re: Crank Question: Do I need to regrind?
That appears to just be a witness mark left from between the bearings ! As it seems to be perfectly centered and very parallel also.
Can you catch a fingernail on it ? If so can you get a much closer "close-up" pic ? ( even if you can catch a nail - if it's perfectly centered then it cannot cause a problem )
68post is offline   Reply With Quote
Old 03-17-2014, 12:21 PM   #3
Poulsbo
Thanks for the fast reply 68post!
I can just barely catch my fingernail...and it appears to be exactly centered. But I'll get a closer, close-up tonight and repost.
Cheers,
Poulsbo
Old 03-17-2014, 01:06 PM   #4
GRX
GRX's Avatar
Ditto on what 68post said. There will be a mark like that on them all after a couple hours of running. Re-inspect everything. Then inspect again.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-17-2014, 01:11 PM   #5
Poulsbo
Cheers,
Poulsbo
Old 03-18-2014, 11:43 AM   #6
Poulsbo
As promised, here is a closer picture of the scratch for reference.
Let me know if you think I have an issue here.
Thanks!
Old 03-18-2014, 12:49 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
Being between the bearings it would be of no impact on anything. You must have goten something trapped between the rods as you mock'd things up?? If you were overly concerend I bet some 1500g wet/dry and some mineral spirits would polish it away in a heartbeat. But I wouldn't even mess with it. You should see some of the DEEP scars I've seen in engines that were assembeled dirty and it never showed anywhere except to the guy that disasembles and shakes his head.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-18-2014, 05:03 PM   #8
Poulsbo
Thanks MarvD, GRX and 68post!
I'll put it out of my mind and get to final assembly.
Cheers!
Old 03-18-2014, 07:23 PM   #9
clinebarger
Scratch from Feeler Gauge??
clinebarger is offline   Reply With Quote
Old 03-18-2014, 07:47 PM   #10
Poulsbo
Red face Re: Crank Question: Do I need to regrind?
Doh! You're probably right clinebarger!
I did triple check the rod side clearance with feeler gauges...and I probably did it myself.
This is my first build...so everything is new. I'll be more gentle next time.
Thanks!
Old 03-18-2014, 08:23 PM   #11
68gmsee
Active Member
68gmsee's Avatar
As mentioned above by others. Just get some crocus polishing cloth at NAPA or at your machine shop and just smooth it out to make sure there aren't any microscopic burrs. Personally, I don't like to use wet/dry sandpaper.
I have a crank I used on my '69 with a slightly wider mark than yours and never had any problems with it. Used it for about 15 yrs.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-18-2014, 09:32 PM   #12
68post
I didn't think it looked like much and it looks even lighter in a close-up , but if you can catch a nail on it - it is something ( a very little something !!).
Old 03-18-2014, 10:09 PM   #13
crazy longhorn
Fabricate till you "puke"
Thanks!
My bet also....I would call it a non issue You have what, maybe .010 side clearance tween the pair of rods ....the bearings will never touch that line! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-19-2014, 12:10 PM   #14
Poulsbo
Thanks everyone!
I'll get some crocus cloth this weekend and touch it up.
Cheers!
350 sbc, crank
