Old 04-01-2014, 08:54 PM   #1
dman1982
dman1982's Avatar
starter wiring???
so kinda a odd question but what wires dont i need anymore?do i need all those wires going from the firewall for the starter since I'm doing my swap? does anyone have a wiring diagram or pics of what i don't need anymore? I'm hoping to put my harness in tomorrow and don't want a bunch of access wiring in there i don't need....84 k10 5.3 swap
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-02-2014, 10:29 AM   #2
littlevictories
Re: starter wiring???
Not sure how it is on an 83, but on my 66 there was a separate passenger side firewall connector for the starter and a couple sensors (originally a 292 in there) and maybe a coil wire. I cut all that out except for the starter wire. I ran that terminal to a relay then to the purple starter wire in the 5.3 harness. Make sure to plug empty connector holes with RTV and be generous with the dielectric grease. Fingers crossed I've only had some very minor gremlins. Good grounds to body, engine and frame are the key to makin these things solid.
littlevictories is offline   Reply With Quote
Old 04-02-2014, 08:37 PM   #3
dman1982
dman1982's Avatar
me and my buddy put my harness in today, he was telling me that gm left most of their wires the same as far as 12 volt +, constant power, and etc, and the colors stayed the same...is what i was really asking was how much can i cut out from the old harness? like the "jumper for the solenoid and etc
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-03-2014, 12:12 AM   #4
littlevictories
man i dunno, I just copied what the lt1swap.com dude has on his site.
Old 04-03-2014, 08:55 AM   #5
Matt Cramer
The starter only needs the battery cable and the crank signal wire. My truck had only one more wire - for the ballast resistor - and the PO had already eliminated that with a HEI conversion. So I just took the wires I had and put them back on the LS starter.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-03-2014, 01:38 PM   #6
dman1982
dman1982's Avatar
When I get home I'm gonna take a pic of what I think your talking about
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-03-2014, 04:07 PM   #7
dman1982
dman1982's Avatar
This is what I was talking about, do I need it?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-03-2014, 04:24 PM   #8
mooseknuckles
mooseknuckles's Avatar
you can delete that if you don't want it...I forget exactly how I wired mine after I removed it, but it's not hard to do...
mooseknuckles is offline   Reply With Quote
Old 04-03-2014, 04:25 PM   #9
dman1982
dman1982's Avatar
What's it for?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-03-2014, 07:18 PM   #10
littlevictories
looks like a power distribution block to me.
Old 04-03-2014, 07:20 PM   #11
dman1982
dman1982's Avatar
It went over to the a/c...not sure what it was for...any ideas?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-03-2014, 07:59 PM   #12
mooseknuckles
distribution block...if you need 12v power, you can tie into it there, not sure why the a/c is wired to it?, but I don't have a/c so can't say for sure.
