04-02-2014, 03:48 PM | #1 |
Rear wheel centering on lowered truck
I keep looking at my lowered 68 and my stock 71 and wondering why the rear wheels sit so much farther forward on the 68. I've looked at a zillion pics of other lowered trucks and it seems to be split. Some look centered and some have the wheels sitting forward like mine. Anyone have an explanation or a fix to it?
04-02-2014, 04:11 PM | #2 |
CAN'T FIX NOTHIN
Re: Rear wheel centering on lowered truck
I am gonna guess that you are seeing the difference between leaf and coil spring trucks ?
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
04-02-2014, 04:12 PM | #3 |
CAN'T FIX NOTHIN
Say could you post some pics of your 68 ?
04-02-2014, 04:54 PM | #4 |
both those trucks in the above pics are coils spring trucks...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
04-02-2014, 05:10 PM | #5 |
Cluster King
That is very strange because typically this happens when the vehicle is raised. I am talking only about coil spring trucks with trailing arms. If you think about what happens to the rear suspension geometry when you raise or lower a vehicle with trailing arms, the rear tire should move forward when you raise and move back when you lower.
Is your 68 a factory built short box truck? Was it also original with coil springs? Any change in the rear suspension from a modified wheel base length will cause this problem. In your case, I think the only good way to fix is to move the rear trailiong arm cross member back enough to center the wheel in the wheel well and drill new holes and bolt it in.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
04-02-2014, 05:17 PM | #6 |
Different wheel offsets and widths along with camera angles. The ones that look "the worse" are the 67-70's with the narrower rear ends with 7 to 8" wheels.
The trucks above are also a shortbed and a longbed. This "appears" worse on shortbeds. Shortbeds have a squared off end at the bottom front of the wheel opening whereas the longbeds have a curve, this also visually helps the wheel appear more centered (see pics above). That's also a sure fire way to tell if you're looking at a true shortbed or a cut down longbed.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-02-2014 at 05:22 PM. |
04-02-2014, 05:49 PM | #7 |
In my opinion, What you're seeing is the 'flat' portion of the axle perch where it sits on the trailing arm sort of rolls forward when you lower the truck. ..
You can flip the front mounts for the trailing arms over (just drill the rivets and literally flip the mounts upside down and replace the rivets with grade 8 bolts. (You have to drill two holes but nbd.) This will roll that flat portion back to approx stock position and get you closer to factory trailing arm geometry too. You'll loose about .5" of drop as well. Ex a 6" dropped truck will look, ride, and feel like it has been dropped about 2-3". You still need shock relocation and adj track bar but the front bracket flip mod will help with the trailing arm situation. Not proven fact.. just my opinion. That and .50 gets you a cup of coffee.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-02-2014, 06:30 PM | #8 |
I appreciate the responses. Little things like this drive me nuts for some reason. Redneck I have spent my whole life looking at and owning several of these and have never seen the difference in the front of the wheel well until you just said it. That just blows my mind. I guess there is always more to learn!
I only have a few pics of it all in the same corner of my shop but there are 2 in my introduction thread from last week-http://67-72chevytrucks.com/vboard/showthread.php?t=622712 |
04-02-2014, 06:44 PM | #9 |
I had never noticed the curve either. Pretty cool
04-02-2014, 10:51 PM | #10 |
the boat guy
You could add a spacer between the trailing arm mount and the crossmember. Probably need to move the top of the spring mount the same.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-03-2014, 12:26 AM | #11 |
I'll look at that when I pull the bed off to do some other stuff. I thought the same as someone above that lowering should push the wheels back. So much for those geometry classes.
Being self employed means nobody answers when I try to call in sick. |
04-03-2014, 06:41 AM | #12 |
CAN'T FIX NOTHIN
This truck looks like may be on a blazer frame ? It looks like the rewr wheels are forward a little bit on this one too , I thought when you lowered a truck the wheels should go back just a bit ?
04-03-2014, 07:27 AM | #13 |
I spaced the trailing arm mount back on my 69 , I think about 3/4" , made a huge difference in the way it looked , at least to me.
04-03-2014, 08:53 AM | #14 |
I think even that much would look a lot better on mine too. Love your truck reminds me of my "Old Blue" from high school.
04-03-2014, 11:52 AM | #15 |
try this to see if its a illusion or if there is a difference, tape string at same location on both trucks just under the molding, thread another piece of string with a small loop in it vertically with a small nut for weight, center the vertical string with the axle and measure that to the edge of the front wheel well along the horizontal string....(confusing the way I'm explaining it) compare the two trucks......
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-03-2014, 12:12 PM | #16 |
I agree that most will look a lot better moved back 3/4 of an inch. I'm in the middle of a LWB to SWB conversion and don't want to permanently mount my trailing arm crossmember until the bed can be set on for this reason.
65 C20 292 4spd 4:56 Eaton HO52 |
04-05-2014, 06:52 PM | #17 |
04-05-2014, 10:07 PM | #18 |
Looks like adding a spacer behind the brackets as mentioned would be a good way to do it not sure about the spring perch yet I was too busy pulling the motor.
09-30-2015, 06:23 PM | #19 |
Older thread I just found, but thought it was interesting... I need to move the wheel back and get the thrust line correct. I'd been thinking of putting spacers of correct thickness between the crossmember and the trailing arm brackets. Seems like a very good way to do this.
09-30-2015, 11:20 PM | #20 |
I didn't see any posts to this thread a year ago , now I'm "that guy" who didn't respond....sorry. I did not move the spring any when spacing the arms back , the springs seemed just fine.
