04-04-2014, 12:06 AM | #1 |
Engine Covers/ Air Cleaner Truck?
Has anybody used one of these covers, or his air cleaners for a truck?
BH Custom Designs Products Tuesday, March 25, 2014 Custom Built Truck LS 4.8,5.3,6.0 Engine Cover With Built In Air Intake System!!!!! This cover is a good way to clean up you engine compartment by eliminating the original air intake tube ,this particular cover has the air intake system with filter inside of the unit.There is a removable vent on top of the cover for easy access to the air filter and mounting bolts,this setup requires plugging the mass air flow sensor to the throttle body then this cover plugs onto the mass air flow sensor.This cover is fabricated from sheetmetal and comes bare metal finished so you can paint,powdercoat or chrome plate it. ▼ 2014 (4) ▼ March (4) CHECK OUT OUR FACEBOOK PAGE FOR MORE PHOTOS!!! GM LS1,LS2.LS3,LS6 Custom Built Engine And Coil Co... Custom Built Truck LS 4.8,5.3,6.0 Engine Cover Wit... Custom Built Truck LS 4.8,5.3,6.0 Engine And Coil ...
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-04-2014, 01:13 AM | #2 |
meowMEOWmeowMEOW
Re: Engine Covers/ Air Cleaner Truck?
I just see text you copied from a facebook page?
04-04-2014, 01:56 AM | #3 |
Old member
This is what he was looking at I think. They have been posted before but I haven't seen anybody here that has used them.
I like this one though the best. Don't know how it would do under a hood though. Unless you had a cowl hood to get the air to it.
04-04-2014, 08:39 AM | #4 |
YES thanks, the black one!
04-04-2014, 09:41 AM | #5 |
Is that dropped part at the front plumbed to the MAF? It looks like you'd have some serious air flow restriction issues and it would likely interfere with the MAF reading. Be interesting to see what it does on a flow bench. On a truck, I'd also worry about how much flow you can get in the space between it and the hood unless running a scoop. The look is interesting, but I'm not sure how it will work from a performance standpoint.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
04-04-2014, 02:18 PM | #6 |
I ordered a cover from Brett on the 28th of March, I can't wait to get it!
04-04-2014, 02:32 PM | #7 |
Registered Cruiser
Anyword idea on pricing?... I'm not on facebook and his website doesn't list prices.
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
04-04-2014, 03:10 PM | #8 |
WOW, real coverage right here folks !!
04-04-2014, 04:05 PM | #9 |
The coil covers are $150 plus $15 shipping the intake cover is $175 plus $15 shipping and the complete kit intake cover and coil covers is $325 plus $25 shipping. I could have bought a plastic cover for $80-100 but I thought this was cool and different so I bought it.
04-04-2014, 04:06 PM | #10 |
Also, this was for a truck intake, he stated the car ls cover is a little more due to more fab work.
04-04-2014, 04:25 PM | #11 | |
Registered Cruiser
04-04-2014, 04:26 PM | #12 |
Will do, I am just getting the intake cover for now.
04-04-2014, 05:01 PM | #13 |
Registered Cruiser
Cool, thanks!
04-05-2014, 12:38 AM | #14 | |
Those prices are well worth the time spent fabing those up. Does he do one off parts?
04-05-2014, 09:14 AM | #15 |
I think he can, he did some coil covers with chevy logo on them and they looked really good. Seems like a nice guy as well. I'll ask him and report.
04-05-2014, 10:52 PM | #16 |
Brett at BH stated he can do one off pieces.
04-06-2014, 09:09 PM | #17 |
Mine are supposed to ship next week. Can't wait to see them in person!
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
04-20-2014, 07:49 PM | #18 |
Got my covers and I'm happy with them. They are pretty fancy and well made.The only downer is that the top cover rear bolt hole doesn't line up with anything on the rear of my 99 intake. Maybe other years are different. Easy fix to drill another hole, but still.
Don't know if any one has thought of this but there is no provision for the oil cap. That means to fill oil you have to remove the top cover so you can remove a coil cover so you can fill it up. The one change i may make is that the covers use aluminum tube spacers to hold them off the intake and valve covers. The problem here is trying to hold the tubes in place while starting bolts. I think I'll tack weld some steel tube under there to make the install easier. Another observation is that the engine has to be pretty far forward to clear the firewall. These things have a pretty big footprint. I ended up with V8 engine brackets in the forward holes and the ebay adapter plates on the block in the front holes(which pushes the engine back some). I had the engine about 3 inches back with 6 cyl brackets before but making it pretty won over maximum engine setback. To be honest, It doesn't sit any farther forward than a stock 350 does in these trucks. Sorry the pics didn't turn out any better.
04-20-2014, 08:42 PM | #19 |
I think they look good!
04-21-2014, 12:38 AM | #20 |
My concern is the stock brake booster clearance to the coil cover.
How far is your valve cover away from the firewall on the passenger side?
04-21-2014, 05:29 AM | #21 |
Good point. Hadn't thought of that, but I am using a smaller 2000 Trans Am booster. The cover had about an inch of clearance.
04-21-2014, 04:03 PM | #22 |
One thing I will say about these covers or any other on our trucks....
many take up a ton of room that you will need up front. So unless you plan on recessing the firewall they extra inch or better you need for these will be needed for fans and such up front. |
04-21-2014, 04:33 PM | #23 |
meowMEOWmeowMEOW
The 99-2000 had a top only square cover, instead of the 3-piece cover adopted by the trucks and vans from then on. Most likely, thats why the stud boss isn't there on yours. It shouldn't be like that on anything but the early early truck engines.
02-18-2016, 09:43 AM | #24 |
Any updates on covers?
What did you use for Air Cleaner location?
02-18-2016, 07:04 PM | #25 |
Don't have the engine in yet. Turning a 69 Chevy long bed into a 67 gmc unibody short bed with a mild chop is taking longer than I expected. I did get the engine built and painted, but still on the stand.
