Old 04-07-2014, 01:21 PM   #1
dman1982
dman1982's Avatar
house under throttle body?
where does the hose thats under the throttle body go? when i got the motor it wasn't hooked up to anything
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-07-2014, 01:52 PM   #2
woodwright
Enjoying left field
woodwright's Avatar
Re: house under throttle body?
I believe the steam port hose runs through there
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-07-2014, 01:55 PM   #3
dman1982
dman1982's Avatar
any idea where it plugs into?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 01:58 PM   #4
Matt Cramer
That is the steam line. It's basically an air purge. One end goes to the driver side cylinder head and the other end was returned to the radiator - preferably at a higher point than the hose barb on the throttle body. If you don't have a good way to get a fitting into the radiator, the not quite as good option is to drill and tap the flat part of the water pump and return it there.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-07-2014, 02:00 PM   #5
dman1982
dman1982's Avatar
so would it go where the over flow tube is?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 02:04 PM   #6
dman1982
dman1982's Avatar
the very top of the radiator is what i meant
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 02:41 PM   #7
Matt Cramer
Not the overflow tube. It goes to the regular tank below the cap.
Matt Cramer
4.8 LS build thread
Old 04-07-2014, 02:51 PM   #8
dman1982
dman1982's Avatar
So I can just use a regular tank beside the radiator?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 04:44 PM   #9
88Ironduke
Its going to be under pressure, so the external bottle is out of the question. It will just fill up the bottle until it over flows. Then you're sad. Tried and true option is to install a radiator hose drain. I installed a drain assembly in to the top hose on a 5.3 with the fitting pointing down, installed a NPT fitting to receive the steam hose. I was worried about getting an airlock on the hose if the steam entered from the top. From the bottom it seemed like it would be submerged in coolant. Not sure if it made a difference but the system worked. Summit racing, look up radiator hose drain.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 04-07-2014, 05:36 PM   #10
First c10
First c10's Avatar
I would search steam line above in the search box. There is a lot of info here. I would post a picture of mine but I don't have one on my phone. I drilled and taped my water pump
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-07-2014, 05:51 PM   #11
dman1982
dman1982's Avatar
88Ironduke
Do you have a part number?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 07:48 PM   #12
dman1982
dman1982's Avatar
Or pics...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-07-2014, 08:22 PM   #13
88Ironduke
Its been a bit, I think it was the Summit sme-2201-11, its 1 3/4"
inch hose in black. Measure your radiator hoses, my project was into a 81' Firebird so it could be slightly different. Keep track of your water pump outlet size as well (lower outlet). If you ever have a bad water pump there will be two different water pumps available with two different outlet sizes. And they are expensive.
Remove the little drain adapter and screw in a suitable NPT fitting with a barbed end to receive the steam hose. A couple small clamps and you're in. I'm certain there are better options or more "correct" options but that was my solution.
Good luck.
88Ironduke
Old 04-07-2014, 11:31 PM   #14
dman1982
dman1982's Avatar
Good luck.
88Ironduke
this looks pretty easy to make, i have those copper pieces at work and pretty sure i can get most or all of this stuff at lowes, going tomorrow to make it happen
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-08-2014, 11:37 AM   #15
tfi rcing
This is what I have done with a couple of swaps,no problems.The portions of the line that go to the throttle body can be eliminated as well.
tfi rcing is offline   Reply With Quote
