04-15-2014, 08:22 PM | #1 |
Brake peddle ratio?
I've been speaking via e-mails with wilwood on the issue of running a booster (vacuum) or using their aluminum master cylinder in a manual set up. They want to know what the "brake pedal ratio" is. I feel like I should know this but I don't. How do I figure out what it is?
Thanks, Wade |
04-16-2014, 02:45 PM | #2 |
Re: Brake peddle ratio?
It's the relationship between the pivot of the brake pedal to where the rod goes to the master cylinder divided by the overall length of the brake pedal.
http://www.piratejack.net/index.php?...d=14&Itemid=21 http://www.mpbrakes.com/techtalk/how...ng-pedal-ratio
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
04-16-2014, 05:03 PM | #3 |
I gotcha! Thank u for taking your time to help. Much appreciated!
Wade |
04-16-2014, 09:37 PM | #4 |
you can change the ratio on these trucks bye drilling a new hole. There is no need for a booster.
04-16-2014, 10:40 PM | #5 |
I've spoken to wilwood and they are saying it should have a firm pedal as is without a booster. I know Keith (n2billet) had built several without ever using a booster. By my measurements the ratio should be 6.75 to 1. Thanks for the responses.
Wade |
04-18-2014, 09:45 AM | #6 |
Are you going to run a booster?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-18-2014, 10:07 AM | #7 |
No sir. I'm going to at least have first hand experience (lol).
Wade |
