04-23-2014, 02:15 PM | #1 |
Better ride?
Got my truck with a leaf spring rear suspension
I'm doing a frame off resto and was curious of what is the preferred rear suspension. Since I have never ridden in a 67-72 with rear leafs i don't know the difference. My buddies 64 on trailing arms rides very good in my opinion Would it be comparable to today's leaf suspension? |
04-23-2014, 03:53 PM | #2 | |
Re: Better ride?
The 68 definitely had the better ride quality.
04-23-2014, 04:03 PM | #3 |
Re: Better ride?
Been doing more research ad look like the coil rear is the way to go as far as comfort.
Going to have to decide if i want to get rid of the leafs or not |
04-23-2014, 08:16 PM | #4 |
Re: Better ride?
I have a 66 and like the ride on coils. I am building a 65 on full air. The coil spring truck rides a lot better than the leaf spring trucks I have had. Be a while before I get to see how the air ride feels.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-24-2014, 04:28 AM | #5 |
Re: Better ride?
If you want that luxury car smooth ride air is the best way to get it.A step down will be coils front and rear.Rear leafs depending on the leafs can ride ok or ride like a log wagon.
04-24-2014, 08:28 AM | #6 |
Re: Better ride?
Well after thinking about it, really dont see many 67-72 trucks with rear leafs so im just going to keep it with the suspension it already has.
In the back of mind i know the coils will ride better but hey its a truck! |
04-24-2014, 10:20 AM | #7 |
Re: Better ride?
Modern trucks use longer leafs, and that is why they ride better compared to old shorter leaf trucks.
The down side is they have more axle wrap if your going to stand on it. Thus slowing down effective reaction time. GMT400 trucks have longer springs, and are the same width as our square bodies. So if you relocate the mounts you could easily install longer leafs compared to any other set-up. |
04-24-2014, 10:56 AM | #8 |
Re: Better ride?
Yes I had noticed they are shorter. Thats what made me think about a trailing arm setup. My old 98 2 door 2 wheel tahoe had the short leafs and it was rougher than any of my trucks.
04-25-2014, 10:56 PM | #9 |
Re: Better ride?
The trailing set-up while great is either a pain in the a$$ to swap in or pretty pricey.
Longer leaves can be done cheap. With a angle grinder, and a drill with good bits. Either way will give you good results, but if it were my truck I would try truck arms. Mostly because I love vehicles that handle. |
