05-05-2014, 10:20 PM | #1 |
[PROJECT] "Hot Rod" 1931 model a Bonneville/ Rolling bones style
So I had an opportunity to buy a 1931 model body, full hood, 32 grille and a 32 frame. For running gear I'll be using 1941 ford front and rear axles, 59A-b flathead V8 with a 39' 3 speed top loader transmission hooked to 41' pedals. The chassis is pinched to fit a model A and then the frame horns were removed and the rails pinched more to tuck them in where the hood sides will be. It will ride on 35-36 (I believe) wire wheels with 750-16 rear and 500-16 ribbed dirt track tires up front.
Here's the pictures so for, Im currently working on the chassis. frame getting Jigged up Pinched to fit model a cowl Horns removed and pinched to fit 32 grille Had to throw the grille on to see what it looked like At first I was going to use the 1941 ford x section here's some of the mock up pictures However I didn't like the looks of it and how it didn't flow back into the chassis right on the rear. So I made my own. Starting to take shape Next it was time to make some motor mounts Then I checked fit and started to set up the clutch arm and linkage That's were I am currently Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 05-05-2014 at 10:26 PM. |
05-05-2014, 10:56 PM | #2 |
Re: [PROJECT] "Hot Rod" 1931 model a Bonneville/ Rolling bones style
I'm in
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
05-06-2014, 01:39 AM | #3 |
6>8 Plugless........
Great work on the frame and cool project! Nice work on the x member too. I'm currently boxing my frame and making a tubular x member on my 40 Ford now.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-06-2014, 10:09 AM | #4 |
Nice work!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
05-07-2014, 07:52 AM | #5 |
thanks, Hope to get the frame out of the JIG this weekend
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
05-07-2014, 04:14 PM | #6 |
Went to a model A frame building class a number of years ago.
Was surprised at how complex they are. I suppose I had model T on the brain? Looking good!
"I feel the need for speed!"... as soon as I am done with my nap. |
05-07-2014, 04:23 PM | #7 |
This is awesome and sucks at the same time... (really want to see your truck completed!)
You're very talented. I'm a great parts cleaner and installer. My "making" skills are very lacking. I'll be following this one as well!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-07-2014, 10:58 PM | #8 |
The Older Generation
The wire wheels would be '35, the '36 had the large "volkswagon" style bolt pattern wheels. Frame is looking good. LockDoc
05-07-2014, 11:11 PM | #9 |
I'm in for this!
05-08-2014, 08:10 AM | #10 |
ok thanks I thought they were but didn't know there was a difference.
05-08-2014, 08:14 AM | #11 |
Thanks, Ya it fun setting up this chassis. A bit different than a 2x4 box one, the rails took some pressure to get them to the width I needed.
05-13-2014, 11:08 PM | #12 |
Well I worked on the frame this weekend got the x member 95% done just need to get some tubing to bridge the top together. Got the pedals mounted and got the side/supports made and welded in. I also got the rear 2 feet of the frame boxed. Also got the tires in and I mounted them a work this week ill get those pictures up this weekend.
Here's the pictures Thanks for looking Justin
05-14-2014, 12:57 AM | #13 |
You giving me motivation for me to get on my model A too. Running flathead/39 tranny also. Except I'm running my original frame. Keep it up man
05-14-2014, 03:02 PM | #14 |
Great fab work. I have to wait to mount my brake assembly until I set my body back on. Looking forward to that.
05-20-2014, 04:01 PM | #15 |
Subscribing!!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-25-2014, 12:48 AM | #16 |
Well I have finally got some more progress done. Last weekend I got the center section of the frame tied together and the frame off the table. I mocked up the axles just to see what it will look like. Also split the wishbones and then I had to order some parts so that was it tell this weekend. Yesterday I got the old spring perches out and new flat top one installed, mounted up the posie spring and drilled the wishbones for the sleeve for the new perch mounts. Mocked everything up to find out the shackles were to short. So today I made longer ones and got the sleeves welded in and chassis setting on its own weight.
Here's the initial mock up pictures Bolted the motor and trans in place for weight and to set caster. Here's the front end setting on its own weight. Tomorrow I hope to get the wishbones cut down and the threaded bung welded in and the frame mounts drilled and the tapered mount also welded in place. I have to ream the taper a little deeper. Thanks for looking Justin
05-25-2014, 01:36 AM | #17 |
Suicide frontend
05-25-2014, 03:02 AM | #18 |
basically Ya, its modeled after the rolling bones style. The grille will hang down in front of it a little.
05-26-2014, 01:49 AM | #19 |
Well I got the wishbones mounted today. Now to figure out the rear...
Here's the front end done for now, Still have to do a friction shock setup. Justin
05-26-2014, 02:10 AM | #20 |
Sweet!!! Excellent work as usual. I just saw you had this new build going and thought...whoa.. I'd better check this out!! Nice work.
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
05-26-2014, 12:47 PM | #21 |
Thanks man!
06-22-2014, 11:19 PM | #22 |
Well in order to get the rear setup at the right height I had to set the body on the frame. Well I had to cut and rebuild the sub frame in order for it the set on the frame right. I also got the body squared and bolted to the frame and made a custom rear body mount. A reattached the shortened rear frame horns so I can run a spreader bar and a push bar. Made a simple smooth firewall and started setting up the rear suspension.
Anyways enough talking and on to the pictures. Also got a longer front spring and fixed the shackle angles Body on after sub rails removed New sub rails Body mounts Reattached rear horns Firewall And the rear suspension started Justin
07-23-2014, 11:23 PM | #23 |
Well here's an update, better late then never...
I got the rear suspension all tack up except for the gussets between the hairpins, there speed holed but I haven't cut them to size yet. Built a pan hard bar and axle bracket. Then I decided it was time to chop it. I started with 5" chop but ended a 5 3/4" and I love it. Got the rear and side windows lined up just have to get the front pie cut and lined up its about 1/2" total off. anyways here are the pictures. Got the rear tires setting right were I want them... Initial 5" chop marked out No turning back now mandatory top on the ground picture And 5 3/4" chop So as I suspected there was/ is a lot of bondo on the car so after the tops welded up the body will come of and Im going to stripe it of it. Here's the rear section lined up, need two slices to line it nicely Im taking this weekend off for a car show, so I'll be back on this the following weekend. Hope you all like Justin
07-24-2014, 12:44 PM | #24 |
sweet ride, watching along.
07-25-2014, 10:03 AM | #25 |
thanks
