Old 05-28-2014, 02:13 PM   #1
Larsonlegacy
Question squeals and pulleys
Greetings,
This is my first thread on this forum, and I hope to be able to contribute more in the future. I have a 1968 GMC C2500 with a 396. The truck was purchased by my grandfather new in 68 and has been passed along so I know quite a bit of the history.
I finished a full rebuild of the engine this month. (bored to ~ 402, new everything including alt, water pump, harmonic balancer) i was hoping that the engine squeal that it has had since I was a child would be remedied with the rebuild..., no such luck.
I have read several threads on squeals and pulleys but I think my situation calls for a little more info. The squeal happens around 2500 rpm whether its under load or just revving and continues until rpms drop. I know its the crank/wp/alt belt. It is also damaging the belt on both sides (not top and bottom). Diameter of crank: 7.8" lwp: 6" alt:2.7" interesting thing is the part number stamp on the WP pulley pulls up a '72 corvette with 350? So I am sure that pulley is wrong. My father remembers something about having the crank pulley replaced for some reason, but cant remember details. Does anyone know the original sizes of the pulleys that this truck came with? The pulleys are lined up as best I can tell. I have no idea where to start and funds have been almost depleted by this point. So I can't throw pulleys at it blindly.
Thanks!
Larsonlegacy is offline   Reply With Quote
Old 05-28-2014, 02:34 PM   #2
imjeff
imjeff's Avatar
Re: squeals and pulleys
Since the pulley grips the belt by the tapered sides I would make sure one of the pulleys doesn't allow the belt to touch the bottom. That's the only thing I can imagine would cause a problem for that long. Just see if the belt sits the same depth in each pulley. If it's in one further then the others it's probably your culprit.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 05-28-2014, 04:47 PM   #3
Larsonlegacy
Thanks for the direction on that. I had read about the Vbelts NOT sitting low enough, which I though might be the crank pulley, but looking at it now, the belt sits below the top of the groove on the wp pulley. Which would makes sense with the destruction of the sides of the belt. Thank you, I think I am convinced its the wp pulley.
Old 05-28-2014, 05:20 PM   #4
cdowns
cdowns's Avatar
have you tried leaning on it and tightened the crap out of the belts?? many times that is all that is required especially on the power steering belt
Old 05-28-2014, 05:32 PM   #5
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
What kind of belt are you using? I had the same problem with my 454 and on the 4.3 in my blazer. Kept getting cheap made belts from autozone/OREILLYs, and finally went back to the Goodyear gator back belt. As soon as I put the belts on, no more squeaking. I hope it's as simple for you.
FRANKENSTEINC10 is offline   Reply With Quote
Old 05-28-2014, 09:57 PM   #6
72_Cheyenne_Super
72_Cheyenne_Super's Avatar
Aerosol belt dressing does a good job eliminating squeals, but sounds like you have a worn pulley you already identified. Wouldn't recommend the "lean into it" option for anyone as that will put too much radial load into the bearings...if there is a noise in a belt system there is a fix for it that doesn't involve over tightening; in general you should be able to get 1.5 times the cross-section thickness of the belt in deflection
72 Cheyenne Super - BB, A/C, tilt, tach, parch
2007 GT500 - Vista Blue/White Stripes - 2.9 Whipple, 72# injectors, Bassani headers, x-pipe and full 3" exhaust, FRPP suspension, FRPP 3.73, L&M Billet TB, KR diff reservoir, C&R cooler & rad, M/T ET Street 2
72_Cheyenne_Super is offline   Reply With Quote
Old 05-29-2014, 03:38 AM   #7
Larsonlegacy
I have tried several belts from Oreille's, Napa and one from amazon.. Not sure about the brand names, however. There was no difference between the belts, but I guess it would hurt to try something a little more reputable. And the belt dressing had no effect either.
I also did over tighten the belt to see if it helped at all, but again, no dice. It did change the pitch of the squeal though.. Lol
I ordered a new WP pulley from Jegs and will update when it arrives. The only other concern I have regarding all of this is that I have less than 1/8 inch play in the alternator position. (between the valve cover and alt when belt is tight) Meaning that I have to remove the alternator to remove the belt. This doesn't seem right, but all parts stores give me the same length belt.
*Making miracles monotonous since 2002*
'68 GMC C2500
396, Quadrajet.
Old 05-29-2014, 09:07 AM   #8
LSUMurse
LSUMurse's Avatar
Usually the length of the belt is in the part number. Assuming changing the length of the belt won't make it rub against anything else, have them give you a couple sizes longer or shorter and see if that helps with clearance. I will warn against just going into Autozone and giving them a length, for some reason Autozone workers tend to not be able to think outside of their computers (just my experience).
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 05-29-2014, 10:04 AM   #9
MARKDTN
I have tried several belts from Oreille's, Napa and one from amazon.. Not sure about the brand names, however. There was no difference between the belts, but I guess it would hurt to try something a little more reputable....
O'Rileys has a house brand which is no good; they also carry Gates which is very good. Same for Advance I believe. NAPA also has Gates as does CarQuest. AutoZone has a cheap house brand and has GoodYear which is fine. Always buy the better belts IMHO (same thing with hoses too). I use Gates on everything.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-30-2014, 12:51 AM   #10
Larsonlegacy
Thanks for the info on belts, I plan on trying a gator back belt after trying the pulley. I'd rather have a solid answer to the cause.
I hear ya on the Autozone thing.. . I don't really go there for advice. I will be sure to update this thread when I have an answer!
'68 GMC C2500
396, Quadrajet.
Old 06-11-2014, 02:32 PM   #11
Larsonlegacy
*UPDATE* I replaced the wp pulley (significantly different from old one) and it changed the squeal in pitch and rpm. I also used the gator belts as suggested with no difference. I have now ordered the crank pulley which also looks significantly different from what's on there now. I guess I should have just gone with a full pulley kit. Oh well... Update in a week or so when the pulley comes in.
'68 GMC C2500
396, Quadrajet.
Old 08-07-2014, 11:13 AM   #12
Larsonlegacy
*SOLVE D* I realize this update is really delayed, I got married and moved on out to Portland which takes some time... Anyway, after replacing all the pulleys and still having squeals, I started replacing mounting brackets. The ALT bracket was the one that fixed it! It seriously did not look misaligned but I'm squeal free. THANKS for all the feedback and help!
'68 GMC C2500
396, Quadrajet.
396, oem, pulleys, squeal
